Offline einotuominen
#1 Posted : 09 May 2023 10:54:10(UTC)
einotuominen
I got this old K83 second hand and I've been driving my decouplers with it. However there was the fourth port available and I hooked a turnout to it.
Seems that it outputs constant current (or ground), like the x84 decoders do. The other ports work just as you'd expect for a turnout decoder.
So my question is, are these configurable with CV and if so, how can I reset the port 4 to work as a normal turnout decoder? If not, I guess the port is broken.
Thanks!
-Eino
#2 Posted : 09 May 2023 12:13:06(UTC)
Hi Eino
If we are talking about 6083, no there are no CVs and the circuit is very simple.
The first generation of these 6083 are using conventional electronic components that you may replace rather easily.
I once repaired one because ofter the transistors are the faulty units
Here is how the PCB looks like
Looking at the transistor you will find the marking and be able to reorder on Internet
The second generation uses SMDs (Surface-mounted components) and I never had to repair one.
Now I phased out those modules because they wait for the Central Unit to indicate when you stop pressing on the keyboard's button. If this order is missed, then the solenoid bruns.
Newer modules 60832 will shut off no matter what
#3 Posted : 09 May 2023 12:45:32(UTC)
einotuominen
Hi Eino
yes exactly 6083. I've paid 10 € for this unit, so I think fixing is it is not really worth it.
I did not know that they don't have auto shut off. All solenoids that I have attached to it have end switches intact (I believe the uncoupler tracks has them too, right?). This was sort of precaution just in case something like this happens. And it did. I would have burned turnout point motor, but luckily I had kept the end switch. (it's in a hidden area, so easy to replace, since no scenery)...
Looks like it would be wise to just buy a 60832 or 60831 (do they actually have anything else different than 60832 does MFX?)
-Eino
#4 Posted : 09 May 2023 21:13:38(UTC)
Yes the 60831 and 60832 are identical except, the last is also MFX capable. MFX capability is not a great asset as a stable setting by switches is way better, I think.
#5 Posted : 10 May 2023 10:00:04(UTC)
... the 60831 and 60832 are identical except, the last is also MFX capable.
The 60832 may be configured to operate in 8 address mode (as compared to 4 pairs/toggles)
And it is black instead of white
#6 Posted : 10 May 2023 10:09:59(UTC)
OR your PC (software) does not send the appropriate command according to protocol
In 4-address "pair" mode you may define whether or not to sense end point cutoff and also the max duration (up to about 10 seconds)
You may also specify the power (PWM) applied (e.g. C-track points need less power than M-Track points)
Individual ports may be configured to stay on, (or continuously perform a pattern - e.g. blinking)
Edited by user 10 May 2023 13:44:37(UTC)  | Reason: Not specified
This page was generated in 0.430 seconds.
