Joined: 21/06/2016(UTC) Posts: 20 Location: California, Placerville
Does anyone have a better home made controller for the Marklin turntable? The factory controller is junk, I have had to take mine apart 4 or 5 different times after minimal use to readjust the copper contacts. I run mine manually as I have never been able to get railroad and company soft ware to talk to the digital controller on the table. Really, just want something simple and reliable. Any help or suggestions would be great. Thanks. Edited by moderator 31 December 2024 04:21:13(UTC)
| Reason: Set correct turntable number
Joined: 11/07/2018(UTC) Posts: 217 Location: Aruba (general), Oranjestad
If you are talking about the 7186 turntable, its "fairly easy" to construct a home made switch with one push button and a toggle switch Diagrams can be found on line
Regards Jean-Pierre
Any chance you might have a link to the drawings? Thanks Charlie
Joined: 04/02/2011(UTC) Posts: 3,566 Location: Paris, France
Hi Charlie The 74861 turntable is digital (Motorola, MFX and DCC). When being used in analogue environment the signal control panel 72760 must be used (your case 1 think). This unit is mostly electronics Märklin provides no drawings and you will find none because of German law. You may get a faulty item from Märklin and they change it under warranty very easily unless you open it. Then the warranty is void. I don't have this particular item, but I use Märklin items since 1961. They produce high quality product but, true you may get a falty item (rarely) Are you sure you are not doing something wrong? Cheers Jean
 1 user liked this useful post by JohnjeanB
Jean: The main problem is the slid switch. It tends to flatten out the copper contacts inside the blue box and so the deck won't turn. I have taken this apart several times and very carefully re bent them and the switch works for awhile. The turntable itself is a beautiful piece and I am really happy with it. The controller is junk in my opinion. I am running my layout with Railroad and Co. and for some reason that software just won't connect with the Marklin digital controller. So I figure 99% of the time I would be at the turntable anyway, why not just manually run the table. There has to be a easy way to make a controller for doing this and connect it. Thanks for your help. Charlie
Hi Charlie Originally Posted by: rustya  I am running my layout with Railroad and Co. and for some reason that software just won't connect with the Marklin digital controller. One way to address the issue is to use the TT with a digital system. Frankly I don't have this TT but another Märklin one and IMO it is just a pity you can't use it that way Here is just a glimpse of my layout with a TT under complete control of digital and association with Rocrail. A few points: - the 74861 does not connect to "that software" but to your "Digital controller" (which one it is I don't know). I use now a CS3 after having used a CS2 since 2010 - If you use an MS2, yes you may have to upgrade to a more intelligent Central Station. I think some use those MS2s with a s/w like Rocrail but you need to add some non-Märklin devices - if you can take a picture of your flat sliding contact, may be we can help. Cheers Jean |
Joined: 23/07/2014(UTC) Posts: 8,491 Location: ENGLAND, Didcot
Originally Posted by: rustya  Jean: The main problem is the slid switch. It tends to flatten out the copper contacts inside the blue box and so the deck won't turn. What is your real turntable, because the 74861 doesn't use a slide switch. Perhaps it would be best if you posted a photo of it, so we can identify it.
hi,my tt is #7286,sorry for the mix up.
Originally Posted by: rustya  hi,my tt is #7286,sorry for the mix up. I suggest you correct the "Subject" of this thread. LDT has a decoder that seems to be better than the Märklin one: LDT decodersThere are other decoders. At least one of them has sound and uses bridge travel control through the use of light. I don't remember the brand. I think other members use it and they can better talk about it. Miguel |
Best regards, Miguel
Mostly Märklin H0.
 2 users liked this useful post by kiwiAlan
Hi If this is indeed a Märklin 7286 controller here is how it should look like when brand new  Notice, there is contact grease to avoid corrosion and wear I never heard someone complaining about this unit Cheers Jean |
Joined: 25/09/2006(UTC) Posts: 945 Location: Sydney, NSW
Originally Posted by: kiwiAlan  Link corrected 30-12-2024 |
Ross
 1 user liked this useful post by Ross
Joined: 13/02/2017(UTC) Posts: 161 Location: Ottawa, ON
Originally Posted by: kiwiAlan  This is the closest I have to a schematic for the 7286 turntable. Hello All, I actually replaced the original Marklin Turntable control box with simple switches. Here's a schematic of a drawing I made.  |
Andry
 2 users liked this useful post by Kiko
Using information from various posts in this forum, i converted 7186 TT control to digital. Nothing too fancy. Just moving one stop at a time. |
 2 users liked this useful post by BenP
