Offline rustya
#1 Posted : 02 May 2023 02:19:02(UTC)
rustya
Does anyone have a better home made controller for the Marklin turntable? The factory controller is junk, I have had to take mine apart 4 or 5 different times after minimal use to readjust the copper contacts. I run mine manually as I have never been able to get railroad and company soft ware to talk to the digital controller on the table. Really, just want something simple and reliable. Any help or suggestions would be great.
Thanks.
Edited by moderator 31 December 2024 04:21:13(UTC)  | Reason: Set correct turntable number
Offline cintrans
#2 Posted : 02 May 2023 02:40:20(UTC)
cintrans
Aruba
If you are talking about the 7186 turntable, its "fairly easy" to construct a home made switch with one push button and a toggle switch
Diagrams can be found on line
Jean-Pierre
Offline rustya
#3 Posted : 02 May 2023 06:45:01(UTC)
rustya
Any chance you might have a link to the drawings?
Charlie
#4 Posted : 02 May 2023 12:15:12(UTC)
Hi Charlie
The 74861 turntable is digital (Motorola, MFX and DCC).
When being used in analogue environment the signal control panel 72760 must be used (your case 1 think).
This unit is mostly electronics
Märklin provides no drawings and you will find none because of German law.
You may get a faulty item from Märklin and they change it under warranty very easily unless you open it. Then the warranty is void.
I don't have this particular item, but I use Märklin items since 1961. They produce high quality product but, true you may get a falty item (rarely)
Are you sure you are not doing something wrong?
Offline rustya
#5 Posted : 02 May 2023 16:57:53(UTC)
rustya
Jean:
The main problem is the slid switch. It tends to flatten out the copper contacts inside the blue box and so the deck won't turn. I have taken this apart several times and very carefully re bent them and the switch works for awhile. The turntable itself is a beautiful piece and I am really happy with it. The controller is junk in my opinion. I am running my layout with Railroad and Co. and for some reason that software just won't connect with the Marklin digital controller. So I figure 99% of the time I would be at the turntable anyway, why not just manually run the table. There has to be a easy way to make a controller for doing this and connect it.
Thanks for your help.
Charlie
#6 Posted : 02 May 2023 18:21:21(UTC)
Hi Charlie
One way to address the issue is to use the TT with a digital system.
Frankly I don't have this TT but another Märklin one and IMO it is just a pity you can't use it that way
Here is just a glimpse of my layout with a TT under complete control of digital and association with Rocrail.
A few points:
- the 74861 does not connect to "that software" but to your "Digital controller" (which one it is I don't know). I use now a CS3 after having used a CS2 since 2010
- If you use an MS2, yes you may have to upgrade to a more intelligent Central Station. I think some use those MS2s with a s/w like Rocrail but you need to add some non-Märklin devices
- if you can take a picture of your flat sliding contact, may be we can help.
#7 Posted : 02 May 2023 21:36:33(UTC)
Jean:
What is your real turntable, because the 74861 doesn't use a slide switch.
Perhaps it would be best if you posted a photo of it, so we can identify it.
Offline rustya
#8 Posted : 02 May 2023 22:05:56(UTC)
rustya
hi,my tt is #7286,sorry for the mix up.
Offline mbarreto
#9 Posted : 02 May 2023 22:41:46(UTC)
mbarreto
I suggest you correct the "Subject" of this thread.
LDT has a decoder that seems to be better than the Märklin one: LDT decoders
There are other decoders. At least one of them has sound and uses bridge travel control through the use of light. I don't remember
the brand. I think other members use it and they can better talk about it.
Miguel
Miguel
Mostly Märklin H0.
#10 Posted : 02 May 2023 23:26:16(UTC)
This is the closest I have to a schematic for the 7286 turntable.
It comes from a document by Ross Stewart in Australia, at http://members.ozemail.com.au/~...table_analog_control.pdf
#11 Posted : 03 May 2023 11:43:26(UTC)
If this is indeed a Märklin 7286 controller here is how it should look like when brand new
Notice, there is contact grease to avoid corrosion and wear
I never heard someone complaining about this unit
Offline Ross
#12 Posted : 30 December 2024 23:11:41(UTC)
Ross
It comes from a document by Ross Stewart in Australia, at https://www.rossmstewart.net/rms...table_analog_control.pdf
Link corrected 30-12-2024
Ross
Offline Kiko
#13 Posted : 31 December 2024 06:05:01(UTC)
Kiko
Hello All,
I actually replaced the original Marklin Turntable control box with simple switches. Here's a schematic of a drawing I made.
Andry
thanks 2 users liked this useful post by Kiko
Offline BenP
#14 Posted : 31 December 2024 15:02:48(UTC)
BenP
Using information from various posts in this forum, i converted 7186 TT control to digital. Nothing too fancy. Just moving one stop at a time.
thanks 2 users liked this useful post by BenP
This page was generated in 0.712 seconds.
