#1 Posted : 01 April 2023 02:42:08(UTC)
http://www.zimo.at/web20...letter_2023_March_EN.pdf
could be of interest:
ZIMO MS decoders also operate in the mfx data format (Märklin). These decoders (equipped with a suitable sound
project, in the future also non-sound decoders with a "decoder project") can register themselves with mfx DCC
command stations, which then show the correct icons, names and images in the cab display.
In the near future, (almost) all common ÖBB and DB locomotives will be available in the best 16-bit quality and
mfx capability on the ZIMO Sound Database. There are also Czech/Slovak sounds and those of SNCF vehicles.
Some exotic sounds from Australia will also be added soon.
The many positive comments from our customers support us in our efforts to offer prototypical and complex sound
projects, so ZIMO sounds are always a guarantee for lots of fun.
thanks 5 users liked this useful post by river6109
Offline PeFu
#2 Posted : 01 April 2023 06:55:12(UTC)
PeFu
Great to see that the housekeeper also is part of the Zimo team, one doesn’t see that often these days. This is the reality for many MR suppliers well known for us needs: Small companies of 1-5 persons, sometimes production in Asia.
Smile
#3 Posted : 01 April 2023 14:24:18(UTC)
I see forward when Märklin will start use Zimo sound decoder that works better than Märklins own mfx decoder. Lets hope when it will happens.
Online marklinist5999
#4 Posted : 01 April 2023 14:39:21(UTC)
Zimo uses a few sound Labs. Leosound, Henning, etc.
Offline Marklineisenbahn
#5 Posted : 01 April 2023 20:34:30(UTC)
Marklineisenbahn
Hi Goofy,
It won’t happen don’t count on it. Märklin parted with LENZ over decoder issues and royalties and Roco parted with Zimo for similar reasons.
Märklineisenbahn
#6 Posted : 01 April 2023 23:31:22(UTC)
When did Roco Part with Zimo ?
#7 Posted : 01 April 2023 23:52:23(UTC)
Hi Goofy,
Märklineisenbahn
Zimo are private electronic company that are produce digital system and sound decoder.
Just Like ESU too.
Märklin did cooperated with Lenz for MM decoder for many years ago.
Parted? You mean divorces? Not sure what you mean...
#8 Posted : 02 April 2023 00:28:26(UTC)
Roco is in Austria, Zimo also, and Roco still uses their decoders as far as I know.
#9 Posted : 02 April 2023 00:29:27(UTC)
Marklineisenbahn
Hi River 6109,
Mea Culpa- I meant Roco parted with ESU!
Märklineisenbahn
thanks 1 user liked this useful post by Marklineisenbahn
#10 Posted : 02 April 2023 08:22:28(UTC)
Although Zimo seems to be the Rolls Royce choice of decoders and digital systems I can't get around their digital components, its to far advanced for me., a person who grew up with the computer and learned all about it, knows all the technical words, it may be a breeze for them for me its just another language, I still got a new Zimo sound decoder from a Roco ÖBB Rh 1144 loco and can't do anything with it, the CV's aren't the same as ESU so I can't manually change them, tried to program a long address and failed miserable., in the end I gave up, I've talked to someone at Zimo, he helped me but with out luck, it just doesn't think in, I'm contemplating sending it back to ZIMO and see if they can program it for me.,
#11 Posted : 02 April 2023 12:50:11(UTC)
I have no problem by use Zimo decoder. Just follow Zimo manual of the decoder. Some of the CV adress you must use program track to change value . Even to reset decoder you must use program track.
#12 Posted : 02 April 2023 12:55:38(UTC)
how do you change an address to double digits ? how do you change the constant braking distance ?
you can use a lokprogrammer as well
#13 Posted : 02 April 2023 14:42:01(UTC)
They (Zimo) use railcom? An issue with a CS3 for mapping cv values. Some, not all can be adjusted. I didn't mess much as the br 218 runs great with factory settings. only the volume is too low, and it came already maxed up, so it only goes lower. This may also be due to a plastic body shell.
#14 Posted : 02 April 2023 19:59:11(UTC)
Simple use CV 29 configuration and CV 18+19 by set higher adress.
Change constant braking distance se page.30!
www.zimo.at/web2010/docu...MS-Sound-Decoders_EN.pdf
#15 Posted : 03 April 2023 16:09:19(UTC)
That is a prime case for using JMRI and a suitable DCC command station. JMRI does all the calculation of required CVs and sets the appropriate bits to turn long addresses. You will probably fine that the Zimo definitions in JMRI will allow you to set up the other things you want as well.
Offline franciscohg
#16 Posted : 03 April 2023 19:44:42(UTC)
franciscohg
Chile
I have been working with zimo decoders for a while now. The are very nice in driving and sound indeed. I do bought an MXULFA back then, so programming is far far more easy. The paid sound projects from Henning, Leosoundlabs and others are just great and not that expensive.
This page was generated in 0.757 seconds.
