Offline PeFu
#1 Posted : 24 March 2023 21:49:03(UTC)
PeFu
I have a green Re 4/4 II engine from the older Swiss digital starter set Mä 29859. I have just replaced the original decoder with an ESU LokSound 4.0 decoder. I’m using the motor settings proposed by ESU LokProgrammer. Running features are nice, except the following: When the engine is decelerating and finally stops, it takes an approx. 1 cm jump, and then stops again. I have tried tuning different combos of CV 5x settings, but most often some new negative features show up.
Would anyone have a suggestion on which CV:s to adjust?
Blushing
Edited by user 25 March 2023 01:29:46(UTC)  | Reason: Not specified
Offline mmervine
#2 Posted : 25 March 2023 00:58:08(UTC)
mmervine
I ran into a similar behavior with the Lokpilot/Loksound 4's in my Lima TGV's. Try adjusting CV 52. Try a setting of 35 or 40 and see if that helps.
Mark
thanks 2 users liked this useful post by mmervine
Offline PeFu
#3 Posted : 25 March 2023 01:33:18(UTC)
PeFu
Thanks Mark! I ended up reading the ESU manual, increasing the CV 55 for ”Parameter I” a bit made the trick! It’s really running smooth now. Note that the camera picked up a higher sound volume, compared to the experience IRL.
Smile
Offline mmervine
#4 Posted : 25 March 2023 01:42:44(UTC)
mmervine
Glad you got it working correctly. I have only had this issue with generation 4 of ESU decoders.
thanks 1 user liked this useful post by mmervine
This page was generated in 0.243 seconds.
