#1 Posted : 17 March 2023 20:28:48(UTC)
I had the idea of using yellow LED strips in the smoking section of my 60s and 70s coaches and bright white for the non-smoker's section
I know that repeated smoke would have yellowed the light covers, but I don't know if it would be that visible from outside.
What do you think about this idea?
#2 Posted : 17 March 2023 23:42:06(UTC)
Good idea Mike but there is quite a difference between the white and yellow LEDs and not sure if smoke would make that difference. You could try on one coach to see the results. I have seen warm white and yellow LEDs where the difference is not as much. Think they came in a LED strip but I forget the manufacturer.
David
Offline dickinsonj
#3 Posted : 18 March 2023 00:29:45(UTC)
I think it would make a difference and not just from the smoke staining the lights. At that time the air was often dark with smoke in many public spaces and that haze filters out a lot of light and changes colors..
I think the idea is brilliant. ThumpUp
Offline Toosmall
#4 Posted : 18 March 2023 04:15:14(UTC)
Toosmall
I agree as above. The yellow LED will just look too yellow.
Just get a Rosco gel swatch book and add a gel or 2 over the light to change colour temperature. It will also drop light output a bit as well.
https://www.bhphotovideo..._Cinegel_Swatchbook.html
https://www.bhphotovideo...els/ci/1329/N/3662541030
I think Rosco 3443 Quarter Straw (Mired shift +42, transmission 81%) or 3409 Roscosun (also, Mired shift +42, transmission 81%) would be a better colour. It's leaning a bit more to a coffee colour (I once cleaned the walls of an office from decades of smoking (not me)).
Offline Toosmall
#5 Posted : 18 March 2023 09:29:36(UTC)
Toosmall
The above link was for the small swatch book.
This is for the larger one 75mm x 150mm (it's the one I have)
#6 Posted : 18 March 2023 10:01:38(UTC)
Mike, wouldn't it be quicker and easier, you just exhale the cigarette smoke onto the Led's and see if it makes any difference and what colour you finish up with, I wonder if it works more effectivly with a cigar, if you are a none smoker just walk onto the street and ask a walking by person who is a smoker.,
#7 Posted : 18 March 2023 20:38:08(UTC)
maybe you could purchase some suitable colourant off the originator of this story ... Scared Scared Scared Scared Scared Scared
Offline Ross
#8 Posted : 18 March 2023 22:10:57(UTC)
Ross
Hi Mike/All,
I had this dilemma and experimented with white and yellow LEDs. See articles below.
LED Light Choice
LED Tinting
Links updated 30-12-2024
Edited by user 30 December 2024 23:19:32(UTC)  | Reason: Not specified
Ross
thanks 3 users liked this useful post by Ross
#9 Posted : 18 March 2023 22:26:38(UTC)
Hi Mike/All,
I had this dilemma and experimented with white and yellow LEDs. See article below.
LED Light Choice
Interesting comparison Ross. I have both of these lighting kits, and have been fitting them on the basis of warm white/yellow for older trains to represent tungsten lamps, and cool white for newer coaches that would have been fitted with fluorescent lighting.
I wonder if the first class sections of the coaches you are showing would in real life have used fluorescent lighting?
#10 Posted : 18 March 2023 22:34:05(UTC)
Hi Mike
I suppose the choice is more between cold white and warm white which you can find easily (5 m rolls with self adhesive)
I have noticed that what is critical for the ambiance is the painting of the interior decoration and the selected colors have a tremendous impact on the looks
Here are some Märklin coatches that are using warm white LEDs strings
The car in the front is standard Märklin lighting
Note: some stained glass paints (Vitrail by Pebeo) allow fun effects
I also use special LEDs for Xmas with integrated IC and light change for adverts
Offline Ross
#11 Posted : 18 March 2023 22:36:32(UTC)
Ross
Hi Alan,
I would never use the Marklin yellow LED lights again because once you put passengers into the coaches with yellow lights they all take on a murky dull look.
I have started to use clear acrylic paints more to change the colour balance of the light output and I also dim the lights so they are less bright.
Hi Mike/All,
LED Light Choice
Edited by user 02 January 2025 01:33:30(UTC)  | Reason: Link corrected 02-01-2025
Ross
thanks 2 users liked this useful post by Ross
Offline Ross
#12 Posted : 18 March 2023 22:40:22(UTC)
Ross
Hi Jean,
Nice LED lighting with the warm white LEDs Looks good.
Ross
#13 Posted : 19 March 2023 00:53:42(UTC)
White interior reflects more and enhances the white. Soft yellow is better for them. Cool or soft white better for grey or black interior.
Offline BenP
#14 Posted : 19 March 2023 05:07:38(UTC)
BenP
I use warm white leds for all lights and add a dab of white acrylic paint to `age` the light.
thanks 3 users liked this useful post by BenP
Offline mario54i
#15 Posted : 19 March 2023 13:33:33(UTC)
mario54i
Neopixels WS2812 ?
#16 Posted : 19 March 2023 21:19:35(UTC)
No, it comes from a Xmas lighting kit where each diode (smaller then old-style diodes) changes progressively colours (Yellow, Blue Red combilation) and powered with a 12 VDC
This page was generated in 0.703 seconds.
