Offline Mille
#1 Posted : 14 March 2023 06:07:25(UTC)
Mille
Can someone show me how all
field filled in on cs3 when using
static ip would look like?
#2 Posted : 14 March 2023 12:03:48(UTC)
Hi Mille
Here is the manual IP address
Here is the CAN part
This works without a router or with a router, using CAT5 cables
I use it to have Rocrail control my layout.
On the PC, don't forget to tell your firewall (Windows Defender in my case) the allowed application and external IP address.
Offline Mille
#3 Posted : 15 March 2023 05:49:09(UTC)
Mille
Thanks Jean
So server dns should be empty
and i need fill in Numbers in CAN too
#4 Posted : 15 March 2023 06:47:57(UTC)
DNS should point to your gateway address, or if that does not work enter 8.8.8.8
This page was generated in 0.380 seconds.
