Offline Janne75
#1 Posted : 11 March 2023 17:19:52(UTC)
Janne75
I got this locomotive as I was going to just do some basic maintenance to it. Everything else is now fixed except it doesn’t run in the forward direction. Reversing unit pulls when I try to change direction but when it should go forwards it just has that electrical ”bzzzzzttttzzzttt” sound LOL . Another direction change and it runs again backwards.
I have changed new traction tyres, new brushes to the motor, cleaned the motor etc. It didn’t change the issue when I soldered those two reversing unit wires to the other contact points. Reversing unit seems to work ok as when I ”cross soldered” those two wires it still runs backwards.
What could cause this? Is the problem in the motors coil winding or where could it be?
Thanks in advance for any help! Cool
Janne
#2 Posted : 11 March 2023 20:39:08(UTC)
Hi Janne
There are 2 points where the trouble can be:
- the direction change relay (bad contact) but you checked it so this is not it.
- the 2 thin enameled wires between the induction coil and the brush holder close to the coil. Typically, while cleaning the motor, one of the wires breaks which prevents the loco to work in one direction. This is most probably what you have and the buzzing sound comes from the relay and this is normal.
So it is about using a thin tip soldering iron and adding a little length of another solenoid and a bit of heatshrink tube (1 mm diameter or less). Alternately, a Liquid Tape insulator (in the USAs) to isolate connections in boats also available on Internet. This is like a plastic coating paint.
This page was generated in 0.244 seconds.
