Offline tweeter
#1 Posted : 08 March 2023 10:03:16(UTC)
tweeter
Hello, what is the difference among these transformers?
#2 Posted : 08 March 2023 10:36:41(UTC)
Who knows?
66471 has a power switch in the cable.
66470 may have protection against reverse transformation inside, but not sure about that.
6647 is good enough for digital locomotives, but requires a distribution panel with a switch and should be used with the reverse transformation problem in mind.
Offline tweeter
#3 Posted : 08 March 2023 10:42:23(UTC)
tweeter
ummm, not sure what does mean
I´m searching one to feed a running test bench, is it ok for that?
#4 Posted : 08 March 2023 10:53:58(UTC)
The 6647 is OK for testing. Pull the plug or turn off with an external switch when not in use. It always draws power when plugged in - like Märklin transformers always did for decades.
#5 Posted : 08 March 2023 12:40:28(UTC)
It is only a possible problem when using two transformers on a layout. There is a configuration where it is possible to connect the secondaries in a way that can give an electric shock if one of the transformers is unplugged.
But using just one on a test bench will be fine.
This page was generated in 0.278 seconds.
