Offline Philipj
#1 Posted : 20 February 2023 19:28:59(UTC)
Philipj
Does anyone here know how to access the bottom cover under locomotive or tender for grease? Leaflet does not have clear instructions... I also need to replace the rear lamp on the tender... I do not want to mess anything up! Thank you.
thanks 1 user liked this useful post by Philipj
#2 Posted : 20 February 2023 23:31:29(UTC)
That's not a br 23. It looks like a br 01, 03, or 001. On every Trix based Marklin I have, you remove the boiler or body shell, and there are either an exposed worm gear on the motor or under the crdan shaft covers. Those have holes in the top of the decoder or pcb board to lubricate. On some, you unscrew the boards,a nd just lift up a bit to get to the gear.
Every later model Loco. has a manual on the Marklin site.
#3 Posted : 21 February 2023 00:15:00(UTC)
That's not a br 23.
Well, the number on the side of the cab is 23 001. Also the product page lists it as a Br23. Unfortunately they don't have a manual to download.
You are clearly not acquainted with Trix Fine Art locos. These are quite different to the normal production locos in that they are hand built brass items, with limited production quantities and much more expensive than the normal production items.
But having noted all that, I am surprised that a Br23 has been done as a Fine Art loco. That product line was kept for quite exotic items with few prototypes.
The product description is quite interesting - note the last sentence ...
Model: Era II, handcrafted model made of
brass with a smoke box door that can be opened, 8-pin digital
NEM interface in the tender. Illuminated dual headlights at the front and rear, changing with the direction of travel, driven by a bell-shaped armature motor
with a flywheel mass in the boiler, 3 axles driven via coupling rods, 2 traction tires,
NEM coupler pockets included as a retrofit kit.
Length over buffer 265 mm
The smallest curve radius that can be negotiated is 547 mm.
Offline shannon
#4 Posted : 21 February 2023 00:25:28(UTC)
shannon
This is a brass locomotive made by Trix fine art series.
You can see the letter of BR23 printed on the cab.
The wheel configuration in this locomotive is 2-6-2 not the same as 4-6-2 in BR01or BR03.
The chassis apparently is more detailed than the products of Marklin and Trix in general.
thanks 1 user liked this useful post by shannon
#5 Posted : 21 February 2023 09:34:13(UTC)
That's not a br 23.
Note that DR built two locos, 23 001 and 23 002, that were completely different from the BR 23 that was built by DB after the war.
This is DRG BR 23.
This page was generated in 0.320 seconds.
