Originally Posted by: andytrain
hxmiesa, thank you for the video - I suspect the BR in my set is not exactly the same as yours, as I believe the lights on my tender do not light up (based on the icon on the box), but probably they are very similar?
Also, I had a closer look at the tracks and I indeed found that more of them (3 at least) have the pins underneath already broken, so I assume that someone had tried already to connect them and the tracks are bad...
so I guess the question is: is loco + carts worth $225? (& I will probably buy an MS2 starter set)
In my opinion... You are being ripped off, and should demand to return the whole thing.
In detail;
Loco might be worth around 100,-. I wouldn't worry about the wear on the slider, and the light is an incandescent light-bulb that can be changed, or maybe it just need to be reseated.
The 5 waggons are worth 10,- each. I wouldn't worry too much about the broken handrail. It's annoying but it happens.
A 50% refund would be adequate, if you really want to stay with the set, and avoid the hassle of returning it.
The rest are bad things; You were not supplied the DELTA controller unit. Track is brittle and practically worthless.
The trafo has some value, but will be worthless once you get an MS2. (Trafo will again have value, once you build a permanent layout, where it can be used for lighting and other stuff.) It´s value would be around 20,-.
What bothers me the most, is the suspicion that the seller acts in "bad faith". The set misses parts, has broken parts, looks used.
Yet I understand that it was sold "as new", albeit old???
Also, I am extremely sorry for your experience; A hobby like this is supposed to REMOVE frustration from your everyday life, not ADD MORE of it.
I hope the whole thing won't take away your interest in the hobby and this brand in particular.
Whether or not you stay with this particular set, you should try to get hold of a starter set with a BR24 or BR74 and sound. It should cost less than the BR41 set anyway...
Edit; I just realized that I am referring to prices in EURO´s, from the point of view of an european, where the stuff is somewhat easier to come by.
I don't know what percentage my price-suggestions should be adjusted with...
