#1 Posted : 06 February 2023 20:46:00(UTC)
When i use my ESU locomotives with M4 protocol i cannot find CV 113 adress that are to adjust power fail pass in the CS3.
Have i missed something?
I did checked after configuration format but no sign of the CV 113.
Any tip?
To use DCC protocol is waste of time when i did register my loco with M4.
Online Copenhagen
#2 Posted : 07 February 2023 00:21:36(UTC)
Copenhagen
I had to look in my notes. I have changed CV 113 on at least some of my locos with power cap, but I can see that I did it on an MS2.. while having the loco on the address 3 in dcc (even if the loco was working in mfx on my CS3). On the MS2 I could read and write different values.
Offline applor
#3 Posted : 07 February 2023 04:41:11(UTC)
applor
I think you'll need to add it as a DCC loco (keep the MFX registration) and after added you can change the CV on programming track, then just delete the DCC entry after you're done.
For me, I use the Lok programmer so haven't had to do it with a CS2.
#4 Posted : 07 February 2023 06:59:39(UTC)
So it is not possible to use M4 protocol to get adress CV 113 to change power fail pass?
I thought ESU did verified that to use M4 protocol register all in the CS3 or ESU own station Ecos?
Offline applor
#5 Posted : 08 February 2023 22:25:19(UTC)
applor
More accurately, the CV 113 is not present within the MFX programming space. I'd have to look at my CS2 but there may be an option to add a CV manually for MFX? I've done that for programming DCC.
The CV's aren't all listed on the CS2, since it doesn't know what the decoder is capable of.
This page was generated in 0.438 seconds.
