Offline Mille
#1 Posted : 06 February 2023 04:15:35(UTC)
Mille
What makes my signal go yellow? Red or green/stop or go is easy to understand but what makes it go yellow or yellow/green??
#2 Posted : 06 February 2023 06:33:38(UTC)
It wouldn´t show yellow alone. It would be yellow+green, meaning "Proceed with caution" or go slowly ahead.
#3 Posted : 06 February 2023 08:14:24(UTC)
It usually is used when the track enters a turnout
Offline Mille
#4 Posted : 06 February 2023 09:03:00(UTC)
Mille
Ok but what triggar my signal to go Yellow/green instead of be red or just green??
#5 Posted : 06 February 2023 09:42:11(UTC)
Depends on the type of signal. The Ks series can show yellow alone. The Märklin H0 signals are from other series.
#6 Posted : 06 February 2023 09:43:42(UTC)
Is it a Märklin signal? Which ref. number?
Maybe it cannot show green/yellow.
Some signals only have two states (red and green), some have three or more states including yellow/green.
#7 Posted : 06 February 2023 17:33:21(UTC)
Yellow means procede with caution with a green signal also. They won't be lit with an all red signal. Red with white means switching manuever allowed, and can be lit along with a yellow/green distant signal. The newest digital signals from Marklin have matching decoders that toggle them.
Offline PeFu
#8 Posted : 06 February 2023 18:46:12(UTC)
PeFu
On your model railroad, it depends on the brand and type of signal you have. If it’s e.g. a signal with one ”plus” cable, and additional cables for ”red”, ”green” and ”yellow”, you could solve this using two switches: One for switching between ”red” and ”green”, and one for switching between ”yellow” and ”nothing”. If you’re digital, you may use two addresses on a k84 or m84 decoder, or a specific signal decoder, instead.
When running digital under a PC software like TrainController, the software controls both the trains and the three aspects of the signal - ”red”, ”green” and ”green/yellow” - within defined rules.
I have signals (on switchyards) that are wired to show only two aspects, ”red” and ”green/yellow”, i.e. they require only one digital address.
thanks 2 users liked this useful post by PeFu
Offline Mille
#9 Posted : 07 February 2023 05:40:03(UTC)
Mille
Thanks for all information
This page was generated in 0.817 seconds.
