#1 Posted : 21 January 2023 10:06:33(UTC)
My CS3 cannot get IP adress.
I have automatic DHCP but nothing happens.
I tried to click by write in numbers but not possible to show up keyboard.
Do you have same problem?
This did happens shortly after latest upgraded to the CS3.
Edited by user 21 January 2023 14:45:23(UTC)  | Reason: Not specified
#2 Posted : 21 January 2023 14:38:22(UTC)
Hi Goofy
Here is the little I know on the CS3 IP configuration:
- you may call for DHCP when deleting the static ID
- whether the CS3 gets an answer back from your router is up to the router.
On my layout I can use my WiFi router or have a direct link (by CAT5 Ethernet cable) provided my Static address is configured like this
The CAN is
This configuration allows me:
- to operate with Rocrail
- to use the MainStation app and MobileStation app
- to use VNC Viewer
- to access the CS3 using my PC and Chrome web browser
Note: very often following an update, some parameters are changed, so better make a back-up before and a restore after
#3 Posted : 21 January 2023 14:44:16(UTC)
I did fixed the problem with another LAN cable.
It works now.
Did tested by use my Iphone as cab control.
This page was generated in 0.257 seconds.
