Offline Allan2805
#1 Posted : 08 January 2023 01:26:43(UTC)
Allan2805
Hi, I have been operating with just my two mobile stations, the original versions, higher amped ones for Gauge 1. But with more digital functions on locos, the existing 60VA transformer powering them does not have enough grunt and overload cutouts occur. So I intend to get a CS3.
Will my MS1's work with the CS3 - or do I have to get MS2's as well?
Thanks in advance.
#2 Posted : 08 January 2023 01:31:07(UTC)
Thanks in advance.
The question has been asked before, and someone experimented, and the answer was yes they do work.
I don't have a link to the thread at the moment, but I do remember BigDaddy doing the experiment and reporting that they do work.
#3 Posted : 08 January 2023 01:45:52(UTC)
Hi Allan
Yes the MS1 works very fine with a CS3 (my case) with the following:
- plugs directly in one of the 2 front sockets or to extensions using a Terminal (Märklin 60125) to be checked as I don't have a hub)
- stores only 10 of your locos. Those 10 locos are designated by the CS3 using the MS1 command
As you know, the MS1 is much simplified compared with MS2 (no control of points and signals, no CV editing, etc) but to use as a local command away from the CS3 it is good.
Note: be extra carefull when plugging as the pins break easily.
Edited by user 08 January 2023 11:58:37(UTC)  | Reason: Correction: Hub 60122 is replaced with Terminal 60125 (line 3)
#4 Posted : 08 January 2023 03:55:36(UTC)
I think that was in the 'New Locomotives 2022' thread.
#5 Posted : 08 January 2023 04:19:29(UTC)
Close...... It was actually the 2021 version of that thread.
https://www.marklin-user...ses---2021-Edition/page4
Kimball asked the question - Posts #165 - #168
#6 Posted : 08 January 2023 10:34:34(UTC)
... or to extensions using a hub (Märklin 60122) to be checked as I don't have a hub)
NO !!
#7 Posted : 08 January 2023 11:21:15(UTC)
NO !!
Confused
NO as in No it won't or NO as in No you shouldn't?
#8 Posted : 08 January 2023 11:56:39(UTC)
I stand corrected, the "Terminal" to be used is the 60125. The 60122 was a hub allowing to increase the number of MS2 (MS1 is not mentioned but the connector and pin layout is the same) on a track module (60112 or 60113 ) . Not in production anymore
https://static.maerklin....0d0c3e62e31434541986.pdf
But it seems to be out of production now.
Offline bph
#9 Posted : 08 January 2023 12:56:54(UTC)
take a look at the Overview system architecture Märklin Digital: (Systemarchitektur)
Overview system architecture Märklin Digital https://www.maerklin.de/fileadmin/media/maerklin-digital/Downloads/Systemarchitektur_Gesamt%C3%BCbersicht.pdf
from: https://www.maerklin.de/en/service/technical-information/maerklin-digital/book-for-returning/downloads
or acording to Märklin use a 60145 and a 60124 (as described in the 60145 manual)
(this is also shown in the cs3 digital book (1st edition)
#10 Posted : 09 January 2023 08:28:30(UTC)
Two Mobile Stations (MS1 or MS2) can be connected at the front, a third MS can be connected using the 60124 adapter cable, more can be connected using hubs - each hub can connect four MS, but each MS requires a 60124 adapter cable.
Cable 60126 can be used between CS and hub to increase the cable length. Theoretically the bus can go up to 100 m, so a few 60126 can be used to achieve a greater distance.
This page was generated in 0.551 seconds.
