Offline Mr. Ron
#1 Posted : 06 January 2023 09:07:30(UTC)
Mr. Ron
Are the link and screw couplings still used on British freight vans? How about the side mounted brake lever?
Offline Bogenschütze
#2 Posted : 06 January 2023 16:54:04(UTC)
Bogenschütze
I'm not an expert on the modern rail scene in the UK but I do live in SE England and see occasional freight movements on my local mainline. The old 4-wheel wagons with side operated brake levers are really only to be found on heritage lines. AFAIK most British freight workings use bogie wagons and are fully vacuum braked with wheel operated brakes when stationary. The screw-link and hook coupling is still the commonest form for loose wagons although some permanently coupled consists may use buckeye types.
Marklin - "The train set I never had as a child."
Keith Bowman
thanks 1 user liked this useful post by Bogenschütze
Offline rmsailor
#3 Posted : 06 January 2023 18:55:58(UTC)
rmsailor
Vacuum brakes are no longer in use with all stock being air braked.
thanks 1 user liked this useful post by rmsailor
Offline Mr. Ron
#4 Posted : 06 January 2023 22:35:16(UTC)
Mr. Ron
[attach]67277
Thank you for the update. Further question on couplings on passenger cars: Are knuckle couplings used on passenger cars exclusively
or link and screw on older wagons? Are British couplers compatable with European couplers? I was watching an old British video about locomotive types used and they showed some cargo vans being sorted at a freight yard. Vans were released and allowed to run downhill to make up tracks. A yard man would run alongside a moving van and using a pole, apply the lever brake. It looked like a very dangerous job. I wonder if they still do it the same today. U.S. yards use retarders between the rails to slow down cars as they are being sorted for a new train make up.
#5 Posted : 07 January 2023 10:11:39(UTC)
Bogenschütze
I believe that all modern passenger coaches in the UK and Europe are coupled with knuckle couplers. This started in the 1950s with the trend for permanently connected multiple-unit trains replacing locomotive hauled trains. On most modern freight wagons the knuckle coupler can be swung down to allow the use of a screw-link coupler where there is a compatibility issue.
Gravity hump marshalling yards do exist in the UK and Europe but since the 1960s they have been large, centralised installations. They are computer controlled and use retarders similar to those used in US yards. The old practice of a shunter running alongside a descending wagon and applying its brake with a pole as a lever was discontinued or certainly phased out about the same time.
Edited by user 07 January 2023 14:22:01(UTC)  | Reason: Not specified
Keith Bowman
Offline Mr. Ron
#6 Posted : 07 January 2023 17:34:22(UTC)
Mr. Ron
Thank you for the information. Since I am in the U.S. I find it hard to get info about European and UK trains.
#7 Posted : 09 January 2023 08:43:26(UTC)
I believe that most passenger coaches in Germany do not use knuckle couplers. They can rarely be seen on freight trains - I only see them on special ore direct trains.
Powered railcars often use Scharfenberg automatic couplers.
Offline rmsailor
#8 Posted : 09 January 2023 10:14:35(UTC)
rmsailor
The LNER before the last war started to fit corridor stock with knuckle couplings. They featured a drop head to uncover a hook for coupling with screw couplings when required. Knuckle couplings were regarded as a safety feature as stock was more liable to stay upright and in line in the event of a derailment. The policy of fitting knuckle couplings was continued by British Railways post-war when the constuction of standard coaches started. today passenger services are almost totally covered by multiple units which feature a fixed or semi-fixed coupling within the set and an automatic coiupling at the outer end.
Edited by user 10 January 2023 09:48:05(UTC)  | Reason: Not specified
#9 Posted : 09 January 2023 22:27:30(UTC)
..I believe that most passenger coaches in Germany do not use knuckle couplers. They can rarely be seen on freight trains - I only see them on special ore direct trains.
From my limited observations in both France and Germany prior to 2019, coaches with screw link couplings and buffers was the norm on locomotive hauled trains.
Even though I travelled also in Austria, Hungary and Denmark I can't say for sure if I noticed any difference.
Offline Mr. Ron
#10 Posted : 09 February 2023 22:34:33(UTC)
Mr. Ron
I believe there was a coupler compatability when the Royal Scotsman toured the U.S.
This page was generated in 0.408 seconds.
