Offline Don Morris
#1 Posted : 02 December 2022 04:36:48(UTC)
Don Morris
I have 4 m8's, 2 second hand, 2 new. The led on the left hand side of all 4 devices flash. as described in the manual. Can anyone tell me why the red and green led's on one of the outlet ports on the one of 2nd hand devices and a red on the other are lit up permanently. The devices are being used to operate uncoupler tracks. I would appreciate any suggestions.
Thanks Ted Morris
#2 Posted : 02 December 2022 08:21:45(UTC)
The m83 ports may be configure for multiple purposes, not just a pair that pulses red and green to switch a turnout or signal.
The later is the default setting, but it sounds like you have inherited a unit that has been otherwise configured.
You could try resetting the unit to factory defaults.
The m83 has been produced in two variants
- m83.1 = 60831 = white
- m83.2 = 60832 = black - mfx configurable
either way
you may reset the unit by setting a value in CV8 (usually documented as a value of 8 for simplicity)
Offline Ted
#3 Posted : 26 December 2022 04:30:46(UTC)
Ted
Thanks Peter for your Reply, I am unsure to where I change the setting , i understand it it via the cs3. Can you describe a bit more fully. Cheers Ted
#4 Posted : 26 December 2022 11:27:30(UTC)
TS did wrote second hand so is suppose it is same as new?
If you want to reset second hand turnout decoder i recommended you try first connect to the programming track and visit adress CV 8 and write 8 in value.
Be sure that adress of the turnout decoder are correct what it stand in the cab control too.
Are yours turnout decoder set at MM or DCC protocol?
#5 Posted : 26 December 2022 11:41:51(UTC)
Moved topic to Digital Sub-Forum
#6 Posted : 26 December 2022 11:46:50(UTC)
I suggest you RTFM - "Read the Fine Manual" - Page 17 of the M83 manual documents the programming process.
This page was generated in 0.506 seconds.
