Offline ddcullen
#1 Posted : 03 November 2022 16:03:38(UTC)
ddcullen
Confused
I have a medium complex analogue M-Track layout. trying to set up automatic locomotive control with 7039/7041 semaphore signals with 5146/5147 switch tracks - HOWEVER - i still want to use 7072 control boxes for manual override of the 7039/7041 when desired (ie. when i wish to be able to manually restore power to a prescribed dead-zone thrown by 5146/5147 when a train doesn't cross over the far 5146/5147 switching track to 'clear' it.)
- question: can the 7039/7041 be set up to use both the switching tracks AND control boxes simultaneously?
Thanks - David
Offline Martti Mäntylä
#2 Posted : 03 November 2022 21:06:45(UTC)
Martti Mäntylä
I don't see any reason why this would not be possible. Just add branching wires from the red and green control wires to a switchbox, in addition to the wires going to the switch tracks. The semaphores do not care how they get the control signal, or whether there are multiple sources for it.
- Martti M.
thanks 3 users liked this useful post by Martti Mäntylä
Offline owidgie
#3 Posted : 08 November 2022 02:46:17(UTC)
owidgie
I am trying to do the same thing, but the problem is that I can turn Signal #2 to green with a control box and it will also turn signal #1 red.
I need to control only a single signal with a control box position. Since I am using circuit tracks, any input from a control box activates the signal behind it.
I tried a 4001 diode with no luck. Am I over driving the diode with analog power?
Rick
Offline Michael4
#4 Posted : 08 November 2022 09:53:02(UTC)
Michael4
Have you considered using 7045 (the remote switch) to break the circuit to the signal you don't want to change?
#5 Posted : 08 November 2022 14:23:03(UTC)
No overdrive, but you need 2 diodes!
-One coming from the 7072 and the other from the track-contact. Both going to the signal.
That is per solenoid, so you would need 4 diodes, if you want to control both red AND green from both the 7072 AND 2 contact-tracks.
Offline BenP
#6 Posted : 08 November 2022 14:44:46(UTC)
BenP
Originally Posted by: ddcullen Go to Quoted Post
Confused
Thanks - David
Add a power feeder track to the blocked section that becomes live (interrupting red wire) when turning on using push-button switch (permanent type, like 7210 switch; not pulse type).
Later adddition: you should only use the switch for track power (red wire; can be 0V); not to share with accessories permanent power (yellow wire).
Edited by user 08 November 2022 23:39:31(UTC)  | Reason: Not specified
Offline ddcullen
#7 Posted : 08 November 2022 22:09:08(UTC)
ddcullen
Confused
Thanks - David
Ahhhhh…. I like this idea! Thx. Very slick! My layout…
thanks 1 user liked this useful post by ddcullen
Offline owidgie
#8 Posted : 08 November 2022 22:50:42(UTC)
owidgie
Hi Henrik, in this very crude diagram, where exactly and what direction do I insert the diodes? Electronics are my weakness! BigGrin
Rick
#9 Posted : 09 November 2022 10:32:57(UTC)
Offline owidgie
#10 Posted : 09 November 2022 18:54:11(UTC)
owidgie
PERFECT!!!
Thank you very much!!
ThumpUp
Rick
Guest (5)
This page was generated in 0.639 seconds.
