Offline Andyroo
#1 Posted : 31 October 2022 02:34:16(UTC)
Andyroo
Hi everyone, I haven't logged in or posted for a long time but I've recently started giving my Märklin lots more attention again. In the course of this I've realised that I need to digitise one loco and replace a couple of decoders in others. I'm quite familiar with carrying out the work, programming, etc but could use some recommendations for a good basic all round multi protocol decoder that isn't too expensive. They will be replacing 60760 decoders from kits mainly and I need something basic (motor and front lights) and reliable that doesn't break the bank. I used to get lokpilot (v3 I think) and Uhlenbrock (not sure which model) but I haven't bought any for the best part of a decade now. I have an MS2 (old and un-updated) which I use mainly but have the option of using a Roco Z21/Multimaus outfit as well, also analogue use sometimes but I'm wary since this killed one 60760 the other day (I was using a white trafo). I'm probably going to buy a few old locos on ebay and keep for this analogue teppichbahning.
So...any recommendations would be most welcome...I'd rather not pure DCC decoders even if I might actually use that protocol, it's better to keep Märklin locos totally compatible I think. Preferably easily available in post brexit UK, I used to buy from Germany all the time but I'm not so sure it's worth it now.
thanks 1 user liked this useful post by Andyroo
#2 Posted : 31 October 2022 12:53:43(UTC)
I gather you live in the UK? Weather or not you buy from Germany, you still are. Duty is included in the price after import I'm sure. I buy from a couple shops there and only pay shipping to the US, no duty that I notice yet. Shop around.
A for modern decoders, you can still get ones with only the MM (Marklin Motorola format), but if they are MFX, then they are both, and also now DCC compatible, like the Marklin CS3 controllers. The Z21 is an excellent system, but uses railcom, MFX doesn't. However, most functions are accessable with it on Marklin mfx models, I think, except the cab driver for example. Same for Roco-Zimo decoder equiped models on the CS3's. You must manually load them into the MS2, or a CS3, but it's mo sweat. What is diffiult are adjusting most parametrs. Same for a Marklin decoder model on a Z21, or ESU ECOS. I think the newest Zimo sound decoders are mfx auto-read as well.
The ESU M4 decodeds are MFX, and DCC only the naming different for brand identity. I run them all with my CS3, and my MS2 connected as an auxiliary. You will want to get yourt MS2 updated. You need a CS3 connected to the web to get it's updates. A shop can do it. The track box also needs them once reconnecting it.
I haven't researched Uhlembrock lately.
#3 Posted : 31 October 2022 13:30:33(UTC)
It is still worth buying from Germany, but choose your dealer carefully. Not all dealers take the MWsT off when selling to the UK. You are likely to find that at the discounted price available from dealers in Europe your items are likely to work out cheaper than buying from a UK dealer, even after paying VAT and postage.
For decoders you have essentially two suppliers, ESU and Marklin. Some people also like Zimo but I haven't tried them.
For ESU, there are the Lokpilot 5 range for non-sound, and Loksound 5 if you want sound. To load sound into a Loksound decoder you will need a Lokprogrammer and software, but you can request a specific project to be loaded by your dealer when ordering the decoder.
For Marklin the current decoders are the mld/3 range for non-sound, and msd/3 range for sound decoders. To load a sound file you will need a Marklin 60971 programmer and software.
The non sound decoders from both companies are around 30-40 Euros, and the sound decoders around 100-130 Euros. If the decoders are more expensive than this they are probably for larger scales.
The software for both programmers is Windows specific, although people report success running the ESU software on Linux and Mac using virtual machines like Wine.
I would also recommend getting a 'decoder tester', which is a board that the decoder plugs into to load software (not needed for this purpose with the Marklin programmer) and test decoder functionality. Both ESU and Marklin offer one of these. The ESU one has a range of connectors that will handle pretty well every decoder connector interface on the market today. I am not sure what the Marklin one has beyond the 21MTC connector as I haven't investigated it as I have an ESU one.
The ESU decoders have a reasonably active support group (https://groups.io/g/Loksound) with some pretty knowledgeable people who are happy to assist, including, periodically, the North American ESU rep.
Personally I would recommend the ESU decoders, as being more open with their information, which makes them more flexible in my eyes. I believe the Marklin ones could be as flexible if they were as open with information.
If you use the 21MTC mounting for the decoders then either brand of decoder can be plugged into the loco. It also allows you to start off with a non-sound decoder, and later on if you wish to add sound it makes it an easy upgrade to change the decoder and add a speaker.
#4 Posted : 31 October 2022 15:26:51(UTC)
Yes, as Alan says, plus; if you want sound, which I think you said not at first, Marklin also sells a pre loaded sound decoder one each for steam, diesel, and electric, or you can have most dealers install a sound file for a nominal fee of about $5 US. This is helpful because a Swiss Re420 has a distinctly different motor sound than a German Loco., a Taurus, and a Vectron for example, still another. The Re420 has clicking of the relays as it's speed increases. A taurus has the do-re'-me-fa-so-la-te-do sound from star off. The horns and whistles also are different.
Offline Andyroo
#5 Posted : 31 October 2022 21:32:54(UTC)
Andyroo
Thanks for all the info, I definitely don't want sound here...these are locos like DHG700, SNCF Y50 and an S Bahn 111. I have a few factory mfx sound locos that keep me happy in that respect and would buy new Märklin locos with sound if I wanted something new. This is just reliably keeping the wheels turning and headlights on basically.
So should I be looking at the latest lokpilot (v5) and maybe Uhlenbrock and Zimo alternatives?
I don't really want to pay more than £30 per decoder if possible, preferably closer to £20...obviously postage rates and things will vary but if I were to buy 3 or 4 at once it might be worth importing...I believe there's some sort of limit before import taxes...£135 possibly, I haven't kept up to date with the rules.
#6 Posted : 31 October 2022 21:36:56(UTC)
The Marklin MLD3 decodrs run about 30 to 40 euros.
Offline STE-BM
#7 Posted : 31 October 2022 23:39:04(UTC)
STE-BM
Yes, £135. Beware some dealers automatically remove taxes from your order e.g. MSL. From experience it's a bit trickier than it used to be but often times still cheaper than most UK dealers.
You can find a lot of details and experiences ordering from europe post brexit in this thread.
thanks 2 users liked this useful post by STE-BM
Offline Andyroo
#8 Posted : 01 November 2022 09:04:21(UTC)
Andyroo
That's useful to know, I think MSL is where I mainly used to order from - Modellbahn Shop Lippe?
Offline Andyroo
#9 Posted : 01 November 2022 11:40:20(UTC)
Andyroo
I'm having a little look on the MSL website now, the MLD3 looks pretty good but there are lots of options!
I used to mainly use either 8pin harnesses or hard wire decoders but the 21pin option seems a good idea.
I do have a spare Hornby TTS sound decoder for a BR Cl.43 knocking about, that would be a strange noise interesting coming from a little Märklin Y50. 🤭
thanks 2 users liked this useful post by Andyroo
Offline Andyroo
#10 Posted : 08 November 2022 23:55:57(UTC)
Andyroo
So further to this as I've been building up and sorting my trackplan last week I had to order a few extra tracks and in the meantime I sorted a few things loco wise with some parts I had. I found amongst all my stuff I still had one 60760 kit and one Uhlenbrock decoder.
My SNCF Y50 with 60760 hard wired in also started working again, although the lights still don't work (never did, can't fathom why, not too fussed).
I installed the 60760 motor parts in my analog S Bahn 111 and wired in a spare 8pin harness that I had from some Hornby OO conversions I did recently. I plugged in the Uhlenbrock decoder and it displayed some strange behavior that I couldn't fathom out nor correct with cv mods - it lunged forwards slightly every few seconds with speed set to zero. I tried a Hattons (UK retailer own brand) DCC decoder I had spare and it was fine.
In the meantime I had also wired a harness into my DHG700 to replace the blown 60760 that was hard wired alongside an ESU magnet at the time (I had used the motor parts for another lok). The Uhlenbrock displayed the same behavior in this.
I also had one Roco multiprotocol decoder that came with a DCC start set V100, so I put this in the S Bahn and it runs nicely.
I then got out my SNCF BB26000 which is fitted with 60760 motor parts and an identical Uhlenbrock decoder to the problematic one - this runs fine, as it did before.
So now I have the Uhlenbrock and two 60760 decoders spare and three more loks to digitise, including the DHG700 which already has the harness in.
I think I'm going to get ESU lokpilot decoders and perhaps just their magnets and retain the 3 pole armatures in the others.
Edit - Just to clarify, not sure I trust the 60760 decoders much, nor the Uhlenbrock.
Offline Andyroo
#11 Posted : 09 November 2022 13:33:25(UTC)
Andyroo
I had expected that this 3047 BR44 ebay purchase would have to be digitised, but it arrived this morning and seems to have a decoder already, along with a smoke unit and telex!
I think it might be a lokpilot, I seem to recall they were insulated and had a little sticker on.
#12 Posted : 09 November 2022 13:55:53(UTC)
I would recommend to stick to decoders of the same brand as your command station, although ESU can read mfx decoders
Offline Andyroo
#13 Posted : 23 October 2024 00:06:53(UTC)
Andyroo
Moving on nearly two years since this thread, I've been playing trains pretty solidly and have some plans now to re-overhaul the DHG700 yet again (I eventually fitted abother spare 60760)...this time it's getting a 21pin Lokpilot 5 in the little harness/pcb they sell along with the ESU remote couplings they make.
Secondly I have a 3031 BR81 from ebay that will get the Märklin 21pin MLD3 (it has lost it's telex in a previous life though which I didn't realise from the ebay pics).
The weirdly misbehaving Uhlenbrock eventually went in the Roco 2L BR 212 that I robbed the factory decoder for the Märklin 111 from and seems ok.
Also the BR44 I mentioned above turned out to have an ESU Loksound fitted! Turned out to be a huge bargain that one!
I'll do a thread about my multipurpose layout soon which now has multiple sections (C tracks and M tracks plus one section/loop isolated so it can be wired for 3L AC or digital, and 2L DCC or digital).
digital decoder recommendations for Delta Locos (Digital)
by dominator 22/02/2018 00:46:00(UTC)
This page was generated in 0.456 seconds.
