Offline muhkau
#1 Posted : 22 August 2022 11:20:56(UTC)
muhkau
Hi, my loco 3001 is stuttering badly at times and is very inconsistent when running. All my other locos run smoothly. Any advice would be much appreciated. Thanks
Offline mvd71
#2 Posted : 22 August 2022 11:41:46(UTC)
Speech therapist?
#3 Posted : 22 August 2022 12:23:13(UTC)
Clean and then a drop of oil. Make sure your tracks are also clean. Do not over oil the wheels where shown in the loco instructions.
#4 Posted : 22 August 2022 12:27:01(UTC)
Speech therapist?
We can be a bit mischievous here - I was going to suggest Beethoven's No 7 in the background might help the Loco
#:~:text=Ludwig%20van%20Beethoven%20%2D%20Symphony%20no,(The%20King's%20Speech)%20%2D%20YouTube
But seriously, as David suggested, clean track, wheels, and check the brushes as a starting point
#5 Posted : 22 August 2022 12:42:48(UTC)
There is a list of things to do:
- clean the weels with a cotton swab and isopropanol or better contact liquid: Loco upside down on a foamy support, power on the loco with one crocodile clip on the slider and the other one on the chassis.
- check if the slider is worn out (Must be EXACTLY flat) . Do not hesitate to change it if needed.
- clean the slider with a cotton swab and isopropanol or better contact liquid
- clean (Lighter fluid) and lubricate (Märklin oil or winter grade auto oil) the axles (remember the current flows though these axles and dirty/greasy axles won't help)
Here is a video on how to clean a Märklin loco
Edited by user 22 August 2022 17:33:59(UTC)  | Reason: Not specified
Offline Eurobahnfan
#6 Posted : 22 August 2022 17:16:23(UTC)
Eurobahnfan
I had a similar problem with an older lok I purchased some time back: in addition to what Jean mentioned above, I also looked closely at the armature and found it was extremely fouled with carbon that had gummed up with the remnants of overzealous oiling. Once cleaned and re-installed, it ran like new… well, as “new” as a 40+ year old lok can ;)
This page was generated in 0.511 seconds.
