Joined: 02/10/2013(UTC) Posts: 847 Location: West Texas
Hello everyone. Hope all is well.
Since many of the new locomotives are being produced with the new Bell Armature motor.
What is the break in process for these new locomotives?
I know, with the 3 and 5 poles motors there was a locomotive break in process which was a lengthy run in each direction. I believe this was primarily to shape the brushes. The new locomotives don't have brushes, so what should we be doing when we get our new item?
Take good care
Dwight
Joined: 23/07/2014(UTC) Posts: 8,496 Location: ENGLAND, Didcot
Originally Posted by: Zme  The new locomotives don't have brushes, Are you sure about that? All the bell armature locos I have come across have a drum commutator with sealed in brushes.
Hello, thank you for your comments. I thought the advantage of the new motor, is smooth, quiet, and no brushes to replace. Perhaps the brushes advantage is just that you cannot replace them but would need a new motor as they are sealed inside.
Have the break-in procedures been impacted by this new motor or would the same procedures be followed with a new locomotive? I have received a few and just run it for a short time to set the gears and lubricate everything.
I am sure this would not cause concerns, but would I be surprised if I followed the often described break-in process.
Thanks again, take good care.
Dwight
Joined: 04/02/2011(UTC) Posts: 3,570 Location: Paris, France
Hi Dwight Definitely, bell-shaped armature motors have a collector. Their rotor includes no iron so smaller inertia and much bigger sensibility to stalling (rotor cooling is not too great). Overall these motors are excellent (but fragile) Definitely, the collector is not the only part that needs break in process.
Here Märklin HO fan and I have observed on almost any type of motor / loco that the operation is much improved after a little number of hours of use. - much smoother operation because of the gear train and motor working surfaces are improving - much better contact with contact tongues (surface treatment is "machined") for a much improved working.
Does this means I break-in locos like in the old days? No, I use them normally but with a reduced last and at medium speeds. Cheers Jean |
 2 users liked this useful post by JohnjeanB
Joined: 19/05/2022(UTC) Posts: 23 Location: England, Greatworth
Originally Posted by: Zme  Hello, thank you for your comments. I thought the advantage of the new motor, is smooth, quiet, and no brushes to replace. Perhaps the brushes advantage is just that you cannot replace them but would need a new motor as they are sealed inside.
Dwight
Hi, I also fly drones which can be upgraded with brushless motors when the factory (brushed) ones expire, externally these sealed motors conceal their inner identity, I have seen the Marklin new gen motors described as brushless and guess until we ‘open this can) there is no way of knowing how many worms actually reside there.?! I have 4 new locos with these motors and will use them without any breaking in process as such, just running the loco only at different speeds to evaluate its performance compared to older gen stock, can only be improved I’m sure?! Please report back on your methods, thanks,,,
 1 user liked this useful post by georgi UK
