Offline 3864jk
#1 Posted : 14 July 2022 21:37:33(UTC)
3864jk
I would be grateful for a copy of the instruction manual or link for instructions for this newly purchased loco
#2 Posted : 15 July 2022 08:54:10(UTC)
What's the item number - we don't carry automagic databases in our heads of items especially 1 Gauge items. Did you not get a manual with your locomotive?
Manuals for the latest Marklin items including G1 are available from https://www.maerklin.de/...service/product-database
Offline 3864jk
#3 Posted : 15 July 2022 12:43:05(UTC)
3864jk
Thanks but no maintenance instructions included and the nearest number, which I can find is 55722 for a DB BR 213 333-8. I have tried the Marklin database with no success
Offline lok151
#4 Posted : 16 July 2022 13:16:35(UTC)
lok151
https://www.maerklin.de/en/servi...2242bfb70401518455bfa86c
This is a link to Märklin Technical Instructions page. Insert item number 55725 which is a BR212 and click on Search. Then click on Manual in the list.
Hope this is some helpful instructions for your BR213.
Offline 3864jk
#5 Posted : 16 July 2022 21:14:02(UTC)
3864jk
Many thanks but the search has not produced a result and I have emailed Marklin on their contact form to see if they have the instructions in their archive. They have been helpful in the past with other searches.
#6 Posted : 16 July 2022 23:50:05(UTC)
Don't know why, I can find it quite easily at 55725.
#7 Posted : 16 July 2022 23:51:06(UTC)
You can do exactly the same thing with the link I gave which is whyI gave it......
#8 Posted : 16 July 2022 23:54:03(UTC)
Yeah, but the database doesn't have an entry for the catalogue number originally given. It does have an entry for the 55725 though, but it is a subtly different class number.
Offline 3864jk
#9 Posted : 17 July 2022 11:43:44(UTC)
3864jk
Many thanks to you all and I have found the instructions under 55725, which is near enough for help with maintenance, as my version is likely to be AC only.
Offline 3864jk
#10 Posted : 28 July 2022 21:50:11(UTC)
3864jk
Here is a reply to my query from Marklin. 600854_1096_Anleitung_55722_55724_Diesellok_BR_213.pdf. Unfortunately the loco has been returned to the seller, as it only moved a couple of feet before smoking! I await to see if it can be repaired or money returned but I suspect that the motor burned out.
This page was generated in 0.373 seconds.
