Offline cintrans
#1 Posted : 17 June 2022 01:52:12(UTC)
cintrans
Aruba
I recently bought a whole bunch of used older K-rails from an estate, loads of flex-rails, switches, curves, etc, etc...
I have a question however on the switches.
Most of them have a lantern, but when i opened the switches there are no lamps inside.
What lamp is supposed to be inserted into that socket?
Has anyone atempted to solder LED's inside instead?
Jean-Pierre
Offline PMPeter
#2 Posted : 17 June 2022 16:02:48(UTC)
PMPeter
Is the yellow wire still connected to the curved lamp socket? If yes then you can replace the bulb with the Marklin standard bulb or an LED equivalent. I believe the old Marklin replacement bulb is part number 60000. So you can look up the LED equivalent on eBay Germany. It is a direct snap in replacement with no additional resistors, etc. required. I did that for all of my switches before I changed them out to the newer styles.
Offline Rwill
#3 Posted : 17 June 2022 21:25:31(UTC)
Rwill
It amuses me to see the picture of an "old" k track turnout. I started Marklin just over 35 years ago and after a simple k track starter set I bought various bits of track second hand including many turnouts as shown controlled firstly through switch boxes then digitally through k83s We then moved on through K track with separate switch motors then onto c track with switch motors and decoders. Lets face it you could write a book about the issues arising from the later switch motors but no one ever moans about the switches as shown above A while ago I was envisaging a lower level to my layout to be used as holding sidings for the layout above. I decided that I would use k track for the lower level as I had plenty and the old style turnouts would be great for under floor reliability. Sorry if I have gone a bit "off track".
#4 Posted : 17 June 2022 22:30:05(UTC)
Hi Jean-Pierre
Yes this first generation of K Track switches with fixed swich motors had illuminated lanterns (lamp is 60000)
I never had this type of track but M Track. Because of the absence of ventilation, the bulbs were short-lived so it makes a lot of sense to replace them with LEDs lamps
The type is MS4 socket, voltage 18 V full rectifier
On ebay.de you may find some high quality ones (full rectification, LED solidly molded on the MS4 socket.
https://www.ebay.de/itm/38424661...%3D%7Ctkp%3ABFBMtu_Dta5g
Yes is is a bit expensive but then you never have to replace them and current draw is negligible
Look here and pick the color you wish
Offline cintrans
#5 Posted : 20 June 2022 02:20:34(UTC)
cintrans
Aruba
Thanks for sharing that information.
We'll try to get our hands on some of those LED's, seems to be the way to go.
I agree, those "build in" older switch motors seem to be a lot beefier then the newer add on's.
Still in the process of sorting, cleaning and testing the switches, uncouplers, etc.... they were removed from a room-sized layout so we are all set on tracks for the foreseeable future! BigGrin
Jean-Pierre
This page was generated in 0.245 seconds.
