Offline Filipe Louro
#1 Posted : 25 May 2022 11:49:25(UTC)
Filipe Louro
I would like to know if the Schönwitz MbS-51279 (or 51280, 51281 and 51286) cable - 0,25 mm2 - is compatible with the Märklin 71411 (or 71412, 71414, 71415 and 71416) plugs.
Thank you very much.
Sincerily yours.
#2 Posted : 25 May 2022 12:44:57(UTC)
Sincerily yours.
I would expect it to be fine, it is similar gauge to what Marklin uses, so will fit the plugs and sockets fine.
Offline Toosmall
#3 Posted : 25 May 2022 16:25:49(UTC)
Toosmall
0.25mm² is not a lot if you have a run of more than a few metres. Use a voltage drop calculator and remember it is the total length of both wires to calculate the resistance.
If you are using multiple runs for power it's not so bad.
This page was generated in 0.359 seconds.
