Offline pmgsr
#1 Posted : 22 May 2022 21:23:46(UTC)
pmgsr
Hi there,
In my come back to my layout (stopped for many many years at the beggining) i found out that there are now m84 and not only k84.
I'm very impressive with the possibilities of m84 for controlling and feedling my lights (with exterior power supply). My question is if it's compatible with CS1? I can't fin any issue unless the mfx compatibilitie because at the time of the last update of CS1 there were only mfx locos.
Thanks.
Pedro.
Pedro Rosa.
Linda-a-Velha / Lisbon, Portugal.
My Layout (Marklin, C-Track, Digital)
thanks 1 user liked this useful post by pmgsr
#2 Posted : 22 May 2022 22:12:05(UTC)
Hi Pedro
I am far from being an expert. Here is the little I know:
- the CS1 is MFX-compatible but its version is a bit old (2008 to 2010). Mine has the software version 2.0.4 (Märklin last one after the hardware update 2.0.3 and before the ESU upgrade (which I don't have) and I don't use the CS1 much now as I use a CS3 (60226) with a 5A power supply 60101.
- there seem to be 2 variants of MFX: one for locos and one for devices (such as 60842). On my CS3, there is a different procedure to discover or erase MFX items for locos or for devices. On the 60842 manual MFX is mentioned for CS2 and CS3 but not the CS1. Mine can register locos but I never tried registration of M83 or M84.
- I don't remember seeing MFX things on the CS1 when dealing with accessories (it did not exist at the time) as it appears on the CS3
BUT, the M84 60842 can perfectly be used in MM2 (Motorola) and customized using CVs as per the user's manual.
The M84 is superior to the K84 as it can drive Märklin start-up signal and control locos (2 independent contacts per output), it can also be controlled by an external control terminal ADDITIONAL to the digital control.
Note: the M83 is also special as it can be set to blink or generate various signals (Mars light, random/fire, etc). For a reason I don't know this was explained in the 60831 manual (check Märklin website for download) but not anymore in the newer 60832 version
Offline pmgsr
#3 Posted : 22 May 2022 23:11:11(UTC)
pmgsr
Jean,
Thanks for the excelent reply.
Hi Pedro
That's exactly my thoughts. I guess that it's much better to buy a m84 now because i will eventually have an CS3 (not so urgent because i use Rocrail a lot more then CS1).
Thanks for the info on the m83 also, i think i already saw those new options also. They're great.
Pedro.
Pedro Rosa.
#4 Posted : 23 May 2022 01:55:16(UTC)
Pedro, I know what you mean because I am a big fan of Rocrail
Here is what I do with it Video on Rocrail in control
This page was generated in 0.357 seconds.
