#1 Posted : 14 May 2022 14:41:24(UTC)
Hi, I ordered a 1000/25 capacitance and got a double set on one pcb board. The other option was the 1000/50. If I need the 50, can I connect them both in series?
Thank's in advance!
Offline rugauger
#2 Posted : 14 May 2022 19:49:38(UTC)
rugauger
Hi there
I think you're mixing some terms here. Capacitance relates to capacitors and specifies the amount of charge a capacitor can hold. Ohms relates to resistors. I am not familiar with bridge rectifiers being specified with either, unless the PCB you mention is a combination of a bridge rectifier and some other components. Perhaps you can post an image of the PCB for us?
Richard
thanks 1 user liked this useful post by rugauger
Offline DTaylor91
#3 Posted : 14 May 2022 21:33:39(UTC)
DTaylor91
Thank's in advance!
If you're feeding 16VAC into the rectifier, the output voltage will be 22.6VDC (16 x 1.414). If these caps are BEFORE the 12V Voltage regulators, replace them with the 1000uF/50V capacitors. If they are AFTER the 12V regulators, they will be fine. Connecting capacitors in series will halve the capacitance.
thanks 2 users liked this useful post by DTaylor91
#4 Posted : 15 May 2022 01:00:34(UTC)
Thank you both! As I am terrible at uploading pics here, I'll decribe it. Two seperate full bridge rectifieres on one green board with a white seam between them. Not meant to be cut easily. I don't have a small dremel cut off wheel. Otherwise, the breaking board may also break the printed circuits.
4 black resistors on the A/C input side each, and the capacitor after to the right. A tan, brownm black and orange zenode diode at the top of each capacitor, and a red LED at each of the D/C output ends.
I'll wire up one to the motor. If it works, it is ok. If it doesn't, I'll wire in the second with it by combining the leads.
#5 Posted : 15 May 2022 13:57:31(UTC)
It works with only one wired up!
This page was generated in 0.511 seconds.
