Offline QQQ1970
#1 Posted : 10 May 2022 06:37:26(UTC)
QQQ1970
I took delivery of M39027 and there is no lok icon. Does anyone have similar issue?
Offline rhfil
#2 Posted : 10 May 2022 12:15:45(UTC)
rhfil
Icons are in the software. What controller are you using? And when was the last update?
#3 Posted : 10 May 2022 13:42:53(UTC)
Some new issue Locos. don't have an icon in the CS3 database, but that one was released well before the last update, so it's odd if it isn't in it. If it is in the CS3 database, the model should also automatically have an icon upon the mfx reading install.
Offline QQQ1970
#4 Posted : 10 May 2022 14:07:01(UTC)
QQQ1970
I use CS3+ and CS2. Maybe I don’t have the latest software version.
Offline rhfil
#5 Posted : 10 May 2022 16:26:08(UTC)
rhfil
You have a number of choices but the easiest is updating the software. The 39027 is pretty new and may not be in the loco icon file in your update. The icons are in a file, don't remember offhand the name. You can also upload the picture from any website - the Marklin one works fine. There is probablt a youtube instruction in how to do that. Only way to get an icon of a non-Marklin loco.
Offline rhfil
#6 Posted : 10 May 2022 16:29:45(UTC)
rhfil
If that does not work you can also go into the loco edit mode and click on where the icon is supposed to be and then enter the Marklin loco number. That should bring up the icon if it is in the file.
Offline bph
#7 Posted : 10 May 2022 19:16:54(UTC)
I'm fairly sure that the 39027 icon was included in the last CS3 update. it's named "DR DDR BR 02 0314-1.png"
Offline QQQ1970
#8 Posted : 10 May 2022 21:43:11(UTC)
QQQ1970
I updated sw and see lok icon now. I also updated CS2 but still there is no lok icon.
Offline bph
#9 Posted : 13 May 2022 16:35:39(UTC)
Have you tried to export the icon from the CS3 and import it on the CS2 ? (I'm not sure if it works, and since I don't have a cs2 I can't test it. But exporting icons from the cs3 to PC works fine)
Offline QQQ1970
#10 Posted : 14 May 2022 15:04:03(UTC)
QQQ1970
I haven't tried so I don't know.
This page was generated in 0.638 seconds.
