Offline zoooctan
#1 Posted : 30 April 2022 19:39:18(UTC)
zoooctan
Singapore
Hello everyone. I hope you're well.
Just wondering if anyone has used Rokuhan's traction tires on their Marklin locomotives and has any experience / advice to share?
Should it also be the 4mm or 5mm one?
Gavin
https://www.1999.co.jp/eng/10301111
https://www.1999.co.jp/eng/10301112
Offline Poor Skeleton
#2 Posted : 05 May 2022 18:25:08(UTC)
Poor Skeleton
Hi Gavin,
Sorry to say, I don't think either will work on Marklin locos. The Rokuhan wheels are grooved to take the tyres and without these grooves I think the tyres will just work their way off the wheels.
I know the ever intrepid toosmall has modified wheels to accept traction tyres, but even he admits that there are a fair number of casualties in the process so I don't think it's something to take on unless you are very skilled operating a lathe.
All the best
Chris
Offline Toosmall
#3 Posted : 05 May 2022 23:57:13(UTC)
Toosmall
I have only ever used heat shrink tube, non heated.
As far as staying on the wheel it will need a groove. I did a few of my locos 3 decades ago. I don't think I could face doing anymore again.
Have you added lead. That is a lot easier & easily removable.
Offline zoooctan
#4 Posted : 06 May 2022 18:11:40(UTC)
zoooctan
Singapore
Hi I have added lead to give additional weight. At this point, I don't really need the traction tires. But I was curious if anyone had used these from Rokuhan before as they seemed to be an easy and "cheap" solution. But if they are not for Marklin wheels, then I'll have to give them a miss.
Thank you
Gavin
Offline parakiet
#5 Posted : 06 May 2022 19:18:06(UTC)
parakiet
some people do wheels. You sent them your wheels and they make a groove.
Do mind the lost pickup of electricity
Offline parakiet
#6 Posted : 06 May 2022 19:25:19(UTC)
parakiet
Forgot to say, there is another approach!
There is mucus you can apply on the wheels, perhaps dilute with some water, let it cure and it gives traction.
The mucus is collected from American Mojave Macho male frogs in mating mode. So stocks tend to run out every year.
Offline phils2um
#7 Posted : 07 May 2022 08:28:39(UTC)
phils2um
Perhaps you mean "Bullfrog Snot"? http://www.bullfrogsnot.com
Phil S.
Offline parakiet
#8 Posted : 07 May 2022 16:40:16(UTC)
parakiet
http://www.bullfrogsnot.com/faq.asp
Scroll all the way down LOL
Offline husafreak
#9 Posted : 08 May 2022 00:17:18(UTC)
husafreak
Ha, I was told to never use that.
Offline parakiet
#10 Posted : 08 May 2022 10:03:23(UTC)
parakiet
as with everything Z related: less is more than enough and you need to practice a lot.
thanks 1 user liked this useful post by parakiet
Offline Schelly
#11 Posted : 08 May 2022 17:50:22(UTC)
Schelly
I should ask, parakiet, have you ever used this stuff "bullfrogsnot" with Z scale locos? I had seen it in model shops and asked one of my mentors and he said absolutely not! Very concerned that it would leave something on the track or gum up the works of the loco.
AKA husafreak
thanks 1 user liked this useful post by Schelly
Offline parakiet
#12 Posted : 08 May 2022 21:42:17(UTC)
parakiet
I did it on one of my cheap marklin F7.
The first few times were a disaster. Easy to put way to much on it. You should add power so the axles turn. And use a toothpick or something else with a very small tip. Let it turn until it is really cured.
If you use way to much you have mess everywhere. If you use to much it can get wobbly.
I am testing with bougie locs to get the technique. They're easy to clean ;)
Considering that for a normal traction tyre you need to put a groove in the wheel or both wheels. That is far more difficult than the 🐸 snot
In hind sight, connection two locs together works better..
Offline parakiet
#13 Posted : 08 May 2022 22:03:28(UTC)
parakiet
https://cs.trains.com/mrr/f/88/t/259004.aspx
Threads like this give many good hints :)
This page was generated in 1.513 seconds.
