Offline BenP
#1 Posted : 25 April 2022 02:15:14(UTC)
BenP
I converted 8 analog locs since last summer, using the basic Marklin decoder that is part of the 60760 conversion set. I am finding that 3 have now failed, starting with lights no longer switching. This after working fine for months.
I have the suspicion that occasional track shorts or power pulses burn the unit. I have no way of testing, so wonder if others have found the same issue. Should I invest in a decoder tester?
I am replacing the failed units with lokpilot5, which allows mfx and has aux connections, and better ride control for only a few dollars more.
#2 Posted : 25 April 2022 04:21:26(UTC)
I have used these sets for many years without any problems. Some of the locos have been through three generations of conntrollers IB1 -> eCOS 1 -> Ecos 2. They are a pretty basic decoder and don't have anywhere near the refinements of an ESU Lokpilot 5 decoder, but they have been very robust for me during my conversion projects. Of course, these decoders don't support mFx (only MM2) or at least the old ones I have don't support the protocol.
Offline Bill L
#3 Posted : 25 April 2022 06:00:02(UTC)
Bill L
I have had 2 of my 60760 decoders fail through the last many years. I think it was my fault. I think I over-oiled the motor shafts, and the graphite brushes with the oil formed a black sludge with the oil and started to fill the 5 gaps of the commutator. The symptom I found out was the the lok would not move when powered up, but if you nudged it slightly it will move. I think the short circuiting between the 5 commutators on the 5 poles killed the decoder. I now use an x-acto knife to scrape the black stuff off between the commutators.
With these decoders, you do not solder the 2 additional "chokes", and reading through a lot of discussions on this forum, I think they may be needed to protect the decoder from sudden voltage spikes from the motor. That is a guess on my part. I do lubricate with much less oil now.
Does anyone know if it is detrimental to use and solder the 2 additional chokes when using the ESU decoders?? The ESU decoder instructions tell us not to use them.
thanks 1 user liked this useful post by Bill L
Offline BenP
#4 Posted : 25 April 2022 06:09:12(UTC)
BenP
I use chokes with 60760 decoder, but not with lokpilot5 (as instructed). Are chokes like capacitors?
#5 Posted : 25 April 2022 08:39:36(UTC)
No, they look like resistors but are there to suppress RF noise affecting other devices (streaky noisy lines on TV's etc).
I've found the 60760 decoders to be very reliable, the only ones I've had failed are where I've done something - bad wire routing causing a wire to be pinched causing shorts.
#6 Posted : 25 April 2022 12:03:39(UTC)
I have used 60760 in small quantities 5 to 10 and never had a failure.
To be honest I purchased most at least 5 years ago, now I purchase mLD2, mLD3, mSD2 or mSD3
Definitely the switch on and off has no effect as many use stop sections in front of signals.
So the problem may be elsewhere.
Is the AC voltage provided to your control unit appropriate (non standard transfo, house voltage higher than specified?
Offline BenP
#7 Posted : 25 April 2022 12:41:09(UTC)
BenP
I checked voltage, ~18v. Main track powered by CS3+ and test/repair track by IB2, both using recommended Marklin power supply.
Offline BenP
#8 Posted : 25 April 2022 12:45:30(UTC)
BenP
What is noise em spectrum generated?
Pinched wires might be it, as they are delicate (i shrink wrap where exposed).
#9 Posted : 25 April 2022 15:21:44(UTC)
https://www.electronics-...equency-noise-basics.php
Offline BenP
#10 Posted : 25 April 2022 20:32:23(UTC)
BenP
I meant what is the interference bandwidth generated by marklin. Does it affect wifi, cell bands? Interference was (is?) an issue in Europe when I was young, affecting over the air signals for tv and radio.
#11 Posted : 26 April 2022 01:16:08(UTC)
Ben, I'm sure you're aware that a noiuse supressor mounted in the track will filter out most of the digital signal, rendering operation nill if any at all.
Offline BenP
#12 Posted : 26 April 2022 02:44:46(UTC)
BenP
Thx for the reminder. Indeed, digital track cannot have frequency filters. Just wonder what the DC motor chokes do, which sit after the decoder's track to DC rectifier. Marklin says install chokes, ESU says not install.
#13 Posted : 26 April 2022 10:44:04(UTC)
ESU decoders support PWM frequencies up to 50 kHz. AFAIK Märklin decoders have far lower frequencies.
ESU recommends reducing the PWM frequency if the chokes have not been removed.
Offline BenP
#14 Posted : 26 April 2022 13:43:44(UTC)
BenP
I read up a little about PWM, but that level of model train electronics is mostly beyond me. I understand that low speed and load behavior are particularly affected, which are much improved for my original 1960s locs after digital conversion and new motors. Seems best for me to follow manufacturer instructions.
#15 Posted : 26 April 2022 15:42:35(UTC)
That's interesting Ben! I don't know if ESU includes a power capacitor like Roco does on most models, or if would have any effect on not needing a noise filter?
This page was generated in 0.602 seconds.
