Offline gus1
#1 Posted : 28 February 2022 19:47:40(UTC)
gus1
Confused Confused
I wonder if you can help me .
I have a large hornby 3 rail track set up and want to motorise my marklin 3 rail turntable 7186 which I have.
I was advised to get the 6915 which has cost me £240 BUT I haven't got any wiring diagrams for the 7186 so don't have a clue how to connect the 2 together - does anyone have
any experience advice please. I'm over 70 and a pensioner and can't afford to write this off
Thank you in advance
#2 Posted : 28 February 2022 20:27:00(UTC)
Originally Posted by: gus1 Go to Quoted Post
Confused Confused
I have doubts that controller will work with the older marklin turntable.
I don't know where you got that advice - whoever told you that is misinformed in my opinion. The 6915 would work with a Marklin 7286 turntable which is the equivalent of the Fleischmann turntable that controller is designed to work with. The 7186 has a very different motor arrangement.
Offline gus1
#3 Posted : 01 March 2022 10:54:40(UTC)
gus1
Confused Confused
morning
I think that the 7186 and 7286 are very similar the only differnce being that the 186 is 3 rail and the 286 is 2 rail - the connections look very similarConfused Confused
Offline PMPeter
#4 Posted : 01 March 2022 16:08:30(UTC)
PMPeter
You have been a member since:: 04/04/2013(UTC)
No. They are both 3 rail turntables. The older 7186 has 10 fixed exit locations, while the 7286 has 48 possible exit locations.
Offline tonyfh
#5 Posted : 01 March 2022 17:11:31(UTC)
tonyfh
Hello Gus, all,
For information about the turntable 7186 see:
https://www.maerklin.de/...elnummer=7186&lang=1
A question to mr. DuckDuckgo gave this one as a result:
https://www.marklin-user...04-7186-Turntable-manual
Almost at the bottom of the page you find a post from Markus Schild with two files attached, I assume these answer all your questions.
Succes, Tony.
This page was generated in 0.279 seconds.
