Offline JDennis
#1 Posted : 05 February 2022 17:06:04(UTC)
JDennis
Picked up a 60986 Marklin sound decoder for a loco with very limited space inside. Soldered the wires from the decoder to the male 8-pin connector in accordance with the Marklin instructions (P28, 29), see pic below. Checked all connections to the pins, etc. All good. (Interestingly, it appears that the wire colors out of the decoder conform not to the Marklin color scheme, but rather to the NEM or ESU color scheme. No big deal.)
Have not wired the other half of the 8-pin into the loco yet, but plugged the 8-pin connector into my ESU decoder tester and EVERYTHING worked perfectly with the generic diesel programming from the factory. Sooooo, wanted to reprogram the decoder with the correct data for the specific loco. Plug the 8-pin into the Marklin 60971 programmer (yes with pin 1 to pin 1), and tried to read the decoder. The MDT3 reports the decoder not answering.
The connector is wired per the Marklin instructions. The decoder works perfectly in the ESU tester. I don’t know yet if it’s going to work in the loco, but figure it should as long as I use the color scheme (NEM/ESU) from the female 8-pin to the various loco parts. But cannot figure why the Marklin programmer can’t see it or the decoder won’t respond to the Marklin MDT3 software.
Any thoughts? Thanks.
Offline Donb
#2 Posted : 05 February 2022 18:22:13(UTC)
Donb
You also have to connect the decoder programming wires to the screw terminals on the 60971 module. See attached photos.PXL_20220205_171806392.jpgPXL_20220205_171923160.MP.jpg
Best Regards,
Don
TFT ECOS, C track and Z scale, mostly DB/DR and SBB, SJ
#3 Posted : 05 February 2022 19:00:55(UTC)
Views messages in topic : 8,601
You don't have to, it should be sufficient to plug the 8 pin plug into the socket in your picture.
To JDennis, I would try turning the plug around. You won't damage the decoder, the connections on the plug are arranged so that the decoder will not be damaged if the plug is the wrong way around (from memory the lights do funny things if this is done in a loco). The NMRA did at least come up with a sensible pin arrangement to ensure no damage occurs.
Offline JDennis
#4 Posted : 05 February 2022 19:36:50(UTC)
JDennis
Thanks. Yes, I did see that diagram/instruction in the 60971 booklet, but didn't see how it applied in this case. Now I am really confused.
It says to attach "the red and the black decoder wire" to terminal D.
As much as the Germans pride themselves on precision, whatever they meant didn't translate to English very well. Does that mean there are two wires, one red and one black, and you hook them both to terminal D?? OK,I can't imagine they mean to attach the red and black WIRES from the decoder to a single terminal, do they?? Besides, those two wires are already soldered to the 8-pin connector to pins 8 and 4 respectively, so I can't imagine you're supposed to unsolder those two wires and hook them both to terminal D.
Or maybe they meant there's supposed to be a single wire that is red and black, and we should hook it to terminal D. Except that the 60986 decoder does not have a single red and black wire.
Interesting idea about reversing the connector. The 60971 board has the "1" pin clearly marked on it, so figured that should be right. Very difficult to reverse it, because the soldered-on wires conflict with the green terminal block. Nonetheless, I managed to bend several pins trying, but they can be straightened -- but it didn't work anyway.
Seems the 8 pin connector includes all the basic wires you normally need to run the loco: motor 1 & 2, track 1 & 2, headlight, taillight, common for lights, and AUX1. So what is a "programming lead"? If you had the train on the track and were programming the decoder with a CS, the two track leads would be the only two involved, and they are included on the 8-pin.
All that said, I'm totally confused, but let me toss out another weird idea: The wires off the 60986, as I mentioned, are not in Marklin colors but rather, ESU. Any chance that's really an ESU decoder in a Marklin wrapper and you need the ESU programmer to do this? Maybe dumb idea, but heck, grasping for straws at this point.
Offline Donb
#5 Posted : 05 February 2022 19:58:10(UTC)
Donb
You only need to connect the blue/X wires, not he red/black. I think thats only required if the decoder does not have a 8 pin plug already connected.
See instruction for 8pin on page 5 in 60971 manual,
I installed one of these decoders recently and uploading software update and new sound project worked fine for me once I connected the Blue/x wires.
Best Regards,
Don
#6 Posted : 05 February 2022 21:43:43(UTC)
If you are using the ESU / NEM colour scheme, normally the orange wire is on pin 1 - at least on ESU decoders it is.
That seems to line up with the page you posted from your decoder manual.
If you don't have the orange wire on pin 1, then maybe you've soldered the wires on the plug back to front.
Offline JDennis
#7 Posted : 05 February 2022 21:54:26(UTC)
JDennis
Donb, thank you, thank you. That brings it all together. OK, the 8-pin, PLUS blu/or to e and blu/yel to f. I know I should have caught that myself, but thanks to all for straightening me out. Just need to dig out those two wires from under where I mounted the decoder, since I wasn't going to need them, right? BigGrin
thanks 1 user liked this useful post by JDennis
Offline JDennis
#8 Posted : 06 February 2022 00:14:44(UTC)
JDennis
Golly, that really should have worked. The way I read the 60971 manual, page 5, you plug in the 8 pin connector, then connect blu/or (blau/orange = bl/or) into slot E, and blu/yel (blau/gelb = bl/ge) into slot F. With the 8 pin connected, those are the only two additional wires you need to connect.
Still encoder will not answer.
OK, now let's be sure the 8-pin is still right. Stick it on the ESU decoder tester and EVERYTHING works perfectly: lights, sounds, motor. So that's not it.
Put it back on the programmer, hook up the two blau striped wires. Can't imagine how one could screw up (catch the pun) the two wires into the screw terminals.
Still won't answer. I just don't get it. I'm jinxed.
Offline Donb
#9 Posted : 06 February 2022 00:46:13(UTC)
Donb
Hi JD,
is this the first time you have used the 60971 to read/program a decoder?
Perhaps its not connecting properly?
When you insert the circuit board into the USB dongle, press the circuit board lightly downwards and it should 'click' into position.
Try a different decoder and see if that will read?
Best Regards,
Don
Offline JDennis
#10 Posted : 06 February 2022 01:13:53(UTC)
JDennis
Good thought, but I've used it on quite a few decoders now, but all with 21 pin connectors. First time with an 8-pin connector -- and of course, no excuses, but completely neglected to go back and read the part on using it on 8-pin set-ups until it was pointed out to me. However, it seems pretty straightforward: plug in the 8-pin, hook up those two blue/x wires, and let 'er rip ....
OR, I missed something else I'm supposed to do differently. I'll keep looking. Thanks.
Offline Donb
#11 Posted : 06 February 2022 01:24:26(UTC)
Donb
You could check the continuity of each of the 8 pins in the socket with the plug with your voltmeter.
Insert the 8 pin plug and check the continuity of each solder point on the plug with the corresponding soldered pin on the backside of the 60971 board. Perhaps one of the pin sockets is bad.
Best Regards,
Don
Offline JDennis
#12 Posted : 06 February 2022 01:45:39(UTC)
JDennis
That absolutely has to be a great idea -- because we both thought of it! BigGrin Already did that. Thanks.
Offline Donb
#13 Posted : 06 February 2022 01:54:34(UTC)
Donb
Well then the only other thing I can think of right now is to connect the third blue wire (Blue/black) which is Decoder ground, and try that?
It shouldnt make a difference, unless there is a ground issue with the 8 pin plug/socket?
You should contact Rick Sinclair at digital@marklin.com and see what he says,
Best Regards,
Don
Offline JDennis
#14 Posted : 06 February 2022 02:35:16(UTC)
JDennis
That's probably worth a try, Donb. Also considered disconnecting the 8-pin connector from the programmer, unsoldering the red and black wires from the 8-pin, connecting the red and black wires together to the D screw-connector, and the Blu/Blk to the G screw, and just taking the 8-pin completely out of the equation. (Can put the red and black leads back on the 8-pin later.) Am i interpreting the instructions correctly for a decoder with no connector then? (BTW, they apparently really DO put both red and black in the same screw connector, and it does make a certain amount of sense when you think about it to ensure zero voltage on the power leads of the decoder.)
Offline JDennis
#15 Posted : 06 February 2022 17:27:15(UTC)
JDennis
OK, mark this on your calendar: Something worked!
I find nothing in the book to support this, but following Donb's suggestion, and on the assumption that it wasn't likely to hurt anything, I hooked the blau/schwarz wire (see. I'm practicing my German, figuring that "how are you" and "can I have another beer" isn't a sufficient command of the language to get very far) to terminal G on that little green block on the programmer. Guess what?
Came right up, recognized the decoder, accepted the new program without a hitch. Went down and tested it on the decoder tester and it all works perfectly. Now just have to finish wiring the chassis and another one of my locos is successfully "digitalized."
Thanks for the ideas from all.
D
Offline Donb
#16 Posted : 06 February 2022 21:02:32(UTC)
Donb
ESU sound decoders with 8-pin interface IE loksound 5 -8 pin, do not have additional programming wires like the Marklin 8 pin decoder has. They are able to accomplish all programming tasks via the 8-pin connection. Far superior in my opinion.
Best Regards,
Don
Offline JDennis
#17 Posted : 06 February 2022 21:30:21(UTC)
JDennis
Can you program an ESU decoder on the Marklin programmer and MDT3 software, or do you need all new stuff?
While everybody has their own preferences and their own reasons for their brand of decoders and other stuff (almost to the point of religious zeal), in this case, you work with whatcha gots. Got a $100 decoder sitting here, sorta need to figure out how to make it work, and with y'all's help, we did.
How come we don't have a "WinK" emoji?
Offline Donb
#18 Posted : 06 February 2022 21:37:42(UTC)
Donb
You would need to get the ESU lok programmer kit, it's just a little more expensive than the 60971 kit, the lokprogrammer software is a free download from the ESU website.
I regret not switching to using ESU decoders a lot sooner.
Best Regards,
Don
Offline JDennis
#19 Posted : 06 February 2022 23:22:38(UTC)
JDennis
Only experience with an ESU decoder was probably half-dozen years ago. Decided to try one. Wired up a conversion loco, installed decoder, and it immediately became too hot to touch. Replaced with Marklin. Worked fine ever since. I know a lot of people swear by the ESU stuff and I've got nothing against them, but I have one more loco half converted, and one more to go after that, then done with those for a while, so probably not inclined to spend another few hundred $ to get the gear to work on a different brand, etc. Maybe some day give them another try. I'm sure they make good stuff. Next phase of my work will be "digitalizing" all my switch tracks and stuff like that. Then need a CS. Then need ....
You know how it goes.
So where's the best dealer for ESU products? I get most of my Marklin stuff from AJC Kids and they're great to deal with, but don't seem to stock a lot of ESU.
Offline Donb
#20 Posted : 07 February 2022 03:41:24(UTC)
Donb
I just got a reply from Curtis Jueng on the topic of the blue wires needed to be connected, he says:
"This really depends on if the Decoder has, or needs, it’s firmware updated. Once the update has been applied, you shouldn’t need the blue wires connected."
So I took out my Class 18 that I had installed the 8 pin decoder, I then connected all the blue wires and updated the firmware.
I then disconnected the blue wires, and then try to read the decoder, and that failed. I reconnected the blue wires and it read the decoder just fine.
Puzzling.
Best Regards,
Don
Offline JDennis
#21 Posted : 07 February 2022 03:59:47(UTC)
JDennis
Very interesting, Don. Did you hook up all three of the blue/x wires, or just the bl/or and bl/yel as shown in the 60971 documentation?
And BTW, who is Curtis Jueng?
#22 Posted : 07 February 2022 04:14:15(UTC)
.....who is Curtis Jueng?
He is from Marklin USA, one of the co-authors of the Marklin Digital Newsletter.
Offline JDennis
#23 Posted : 20 February 2022 22:39:36(UTC)
JDennis
Don:
When we left this topic a couple weeks ago, you had updated the firmware and tried to talk to the decoder without the blue wires connected -- and it still didn't work. So you said you reconnected the blue wires and worked fine.
My question was/is, did you have to connect all THREE of the blue/xx wires (including the third one, the BL/SW), or just the first two?
Inquiring minds want to know. BigGrin Thanks.
Dennis
Offline Donb
#24 Posted : 20 February 2022 23:19:42(UTC)
Donb
Don:
Dennis
Hi JD,
I had connected all three blue wires, but afterwards after the loco was reassembled, I thought I should have tried connecting just the Blue/black (decoder ground) wire and see if that works. Oh well.
Best Regards,
Don
Offline JDennis
#25 Posted : 21 February 2022 01:20:18(UTC)
JDennis
Thanks, Don.
This page was generated in 1.480 seconds.
