Offline Puttputtmaru
#1 Posted : 28 January 2022 21:23:50(UTC)
Puttputtmaru
I have noticed on two occasions, on a large layout, that people have incorporated next to the usual roundhouse workshop, a building with a large high chimney with a track leading to it. (See the one pic below)
I don’t seem to be able to find what it is for, any ideas?
https://www.marklin-users.net/forum/resource.ashx?a=64140&b=1
thanks 1 user liked this useful post by Puttputtmaru
#2 Posted : 28 January 2022 22:35:20(UTC)
I think it's a Faller brickworks or boiler house.
#3 Posted : 28 January 2022 22:58:33(UTC)
Puttputtmaru
Thanks for that but what I was asking is more the purpose of the building but all the better to have a model to do it with.
So why a brickwork or boilers house near the round table?
thanks 2 users liked this useful post by Puttputtmaru
#4 Posted : 28 January 2022 23:04:03(UTC)
Before electricity, a steam engine would have rotated the turntable. Afterwards, a steam plant generator may have made the electricity.
thanks 3 users liked this useful post by marklinist5999
#5 Posted : 28 January 2022 23:25:16(UTC)
Puttputtmaru
Thanks for that.
It had never dawned on me how the turntable was made to turn before electricity. Just great I love the idea and will incorporate it in my plans for the turntable, including smoke for the chimney of course. I think era IV will still qualify for it
Offline Bogenschütze
#6 Posted : 29 January 2022 13:45:36(UTC)
Bogenschütze
Thanks for that.
In the UK, especially at the smaller loco sheds, many turntables were manually rotated by the crew. Obviously the loco had to be balanced dead centre so that the table could be easily pushed. At larger sheds before electric motors were fitted to turntables, the steam locos generally had vacuum operated brakes, and it was quite common for turntables to be operated by vacuum motors worked from the locomotive's own vacuum ejector or pump connected via a flexible hose or pipe.
So boiler houses to generate steam for operating turntables would not have been common in the UK.
Marklin - "The train set I never had as a child."
Keith Bowman
thanks 7 users liked this useful post by Bogenschütze
Offline HO Collector
#7 Posted : 29 January 2022 23:12:29(UTC)
HO Collector
Never knew this, but I know that the Brits did love vacuum. During WW-II and after aircraft brakes were vacuum operated.
thanks 4 users liked this useful post by HO Collector
Offline hvc
#8 Posted : 30 January 2022 08:28:31(UTC)
hvc
The workshops and the roundhouse had a lot of heavy equipment that needed to be run - this used to be steam driven, and of course later electric. Also, a handy supply of steam could be used to warm-up a locomotive that had dropped its fire. In cold climates steam pipes could also be used to heat outside areas to keep them clear of snow by running pipes in the ground.
Here's a static steam plant at the old Eveleigh locomotive workshops in Sydney, which is very obviously built from locomotive boilers:
http://www.australianste...36%20class%20boilers.htm
Sometimes an old steam locomotive would be parked next to the workshop and used as the static steam plant. I can't find a photo of one right now because I can't remember the German name, but I think it was Faller that made a model of this to put next to a roundhouse or workshop, with an extra long smokestack attached and then steam pipes from the loco into the plant. Maybe someone knows the German name for this?
- Herman
- Herman
thanks 5 users liked this useful post by hvc
#9 Posted : 30 January 2022 14:59:41(UTC)
Puttputtmaru
That would be a pretty neat idea to represent on a layoutWub
Offline Jimmy Thompson
#10 Posted : 30 January 2022 18:59:31(UTC)
Jimmy Thompson
The German term is "Heizlok" (literally "heat Lok") Image from Eisenbahnstiftung:
(25.04.1975) Foto: Joachim Claus
Märklin even had a version of the stack, although they are hard to find:
https://www.maerklin.de/de/produ...article/74500?no_cache=1
Gives an idea.
More info here:
https://bundesbahnzeit.de/seite.php?id=386
Jimmy T
Dr Dirt's Rule #1 and
thanks 4 users liked this useful post by Jimmy Thompson
#11 Posted : 30 January 2022 22:47:00(UTC)
And Märklin even offered the complete scenario for a roundhouse (or any railway or industrial plant) with the model loco and chimney.
An out of use BR 75 model #37133 complete with extended chimney.
(This model had an MFX decoder and could be used to run on a layout).
37133
Offline hvc
#12 Posted : 30 January 2022 23:30:44(UTC)
hvc
Thank you! That is super hard to Google without the right term - couldn't find it at all.
I think it's a really interesting detail for a layout.
- Herman
- Herman
thanks 3 users liked this useful post by hvc
#13 Posted : 30 January 2022 23:50:27(UTC)
Jimmy Thompson
Herman wrote:
"super hard to Google without the right term"
I do not know why! It seems to be able to read my mind the rest of the time LOL LOL LOL LOL
Anyway, you are most welcome! We are all in this together! Cool
Jimmy T
#14 Posted : 30 January 2022 23:51:58(UTC)
Jimmy Thompson
Kimball,
Thanks! I had forgotten Mother M had made a set with the Heizkamin and the lok! Cool
Jimmy T
#15 Posted : 03 February 2022 14:31:05(UTC)
Jimmy Thompson
Here is a video (narration in German) that shows a number of possibilities for Heizlok "operations": source TheTraintv
"At the end of their active time, many steam locomotives are converted into heating locomotives or steam dispensers. At the beginning of the 1990s we observed the Schöneweider locomotives heating the points, were in Stassfurt with 01 024 and in Cottbus with 44 1412. Have fun watching."
Jimmy T
thanks 5 users liked this useful post by Jimmy Thompson
Offline 1borna
#16 Posted : 05 February 2022 21:16:47(UTC)
1borna
Croatia
In larger workshops, the water in the water tower was also heated in a boiler that was in such buildings with a high chimney! This saved coal in locomotives that would heat up faster to operating temperature.
thanks 3 users liked this useful post by 1borna
Offline Nightowl999
#17 Posted : 11 February 2022 17:19:54(UTC)
Nightowl999
My first real car - a Wolseley 6/110 Mk2 had vacuum brakes, with a purple servo warning light when the vacuum for the brakes to work was insufficient.
It was bit disconcerting when the lamp went on at 70mph!
#18 Posted : 11 February 2022 19:26:12(UTC)
I did my initial driving lessons with my father on the family Wolseley 6/90, the 1958 model that had a floor change. There was a linkage to a column change gearbox. I believe the early versions of the 6/90 had column change but later ones used the same gearbox with a linkage to a stubby gear lever on the right hand side of the drivers seat.
It also had vacuum power brakes, which one really needed to stop a vehicle that was a ton and a half dry weight.
[edit] corrected car model [/edit]
Edited by user 12 February 2022 11:33:18(UTC)  | Reason: Not specified
#19 Posted : 12 February 2022 03:16:25(UTC)
I don’t know much about modern cars but it would not surprise me if the servo-assisted brakes still use the vacuum diaphragm.
The windscreen wipers on my first car were vacuum operated. Vacuum “motors” were probably cheap to make. Electric batteries, charging mechanisms and electric motors were primitive and costly.
The vacuum created by an engine is a cheap means of power. In a steam engine the vacuum is created by the draft in the smoke box and that vacuum was applied throughout an English train to keep the brakes OFF. A lever valve allowed Atmospheric pressure to enter the system to put the brakes ON.
In a carbureted internal combustion engine I think the vacuum is created in the fuel inlet manifold. Maybe the same happens in a fuel injected engine.
#20 Posted : 12 February 2022 11:36:14(UTC)
Yes, it is caused by the engine drawing air past the butterfly valve, which creates the vacuum. This is why the vacuum is lowest when the foot is hard on the throttle, causing the valve to be fully open, hence the least constriction in the air path. I would expect an injected engine ot be similar, as the throttle still operates a butterfly valve.
#21 Posted : 12 February 2022 14:12:57(UTC)
Manifold vacuum is highest downdraft of the fuel or throttle controls.
This page was generated in 0.654 seconds.
