Offline anthpao
#1 Posted : 24 January 2022 12:41:40(UTC)
anthpao
My greadings to all the forum.
I have a weird problem with my TGV POS decoder. Although it can produce all sounds, the decoder is not recognized as a sound decoder.
See the pictures I attached.
See that you cannot edit sounds.
See that volume is geyed out.
P.S. I tried reset but sound tag does not load.
#2 Posted : 24 January 2022 13:17:36(UTC)
This picture suggests the firmware in the decoder is very old. I would start bt doing a firmware update on the decoder, and then see what happens.
Offline anthpao
#3 Posted : 25 January 2022 00:58:20(UTC)
anthpao
Any suggestions how to perform a firmware update with cs2?
The decoder is from Marklin with sounds for the TGV POS not an mSD that you can put any sounds you like.
Edited by user 25 January 2022 20:01:02(UTC)  | Reason: Not specified
This page was generated in 0.503 seconds.
