#1 Posted : 17 January 2022 15:10:32(UTC)
I have an Intercity newest long car 4 unit consist with current conducting couplers. It was tracking just fine last fall. Now being winter, my basement is 7 to 10 degre's cooler. I took the train out of it's storage bin yesterday, and the 43630 cab control car is derailing on the rear bogie on level
R3 C track curves. Not R2's. I checked the wheels and pick-up shoe, and all look ok. Not crooked or bent. The direction of travel makes no difference. Even on the R1 curves and turnouts, it goes through smoothly.
Any thoughts?
#2 Posted : 17 January 2022 15:36:04(UTC)
temperature (and humidity) difference may be distorting the track
#3 Posted : 17 January 2022 16:04:46(UTC)
Thabk's Dale I checked, and the track is flat through the tunnel.
Offline rhfil
#4 Posted : 17 January 2022 16:59:33(UTC)
rhfil
Check to see if the bogie moves freely. I had passenger cars that were derailing and the cause was the bogie sticking and causing the wheels to come off the track on corners. I worked them and lubricated them to remove the obstruction and the problem went away Try removing the lok and then moving the passenger cars slowly around the curve while watching the wheels. If some come off the track you have the same problem.
#5 Posted : 17 January 2022 17:40:25(UTC)
Hi Märklinist5999
I have the same issue on many of my Märklin Passenger cars.
What happens?: The cars were derailing without apparent cause (derailing never happens on C Track). The coupling and its short coupling mechanic has become very stiff. All of those are equipped with the Märklin contact blade to bring power to the coupler pocket.
On Which cars?: DB passenger cars, Swiss passenger cars
Many of these Trains were not rolling for a while (a few month) in a zone where temperature can drop below 0°C
Fix? I don't know yet I need to open the stiffest car. Note: in the past I have sprayed some contact spray. Did it cause the issue? I am not sure.
So some work for the next train session (less than 2 weeks time I hope)
#6 Posted : 17 January 2022 17:58:46(UTC)
Thank you everyone!
Offline rhfil
#7 Posted : 17 January 2022 18:02:17(UTC)
rhfil
I applied a teflon spray anywhere plastic parts rubbed against each other in a curve. I needed to remove the bogie to spray the area under it. I wish I could find a lubricant spray, teflon, graphite, or substitute which was more controllable. The large sprays need to be carefully controlled.
#8 Posted : 17 January 2022 20:33:26(UTC)
I had one car's coupler guides that were not moving easily at both ends. I used a needle applicator and light plastic compatible synthetic oil. I think I got it to flow inside thebottom of the guide.
Offline DTaylor91
#9 Posted : 18 January 2022 04:07:05(UTC)
DTaylor91
Say no more! I mainly use their teflon grease, and for more than just model railroad applications:
https://labelle-lubricants.com/model-train-lubes/
thanks 1 user liked this useful post by DTaylor91
Offline danmarklinman
#10 Posted : 20 January 2022 17:45:05(UTC)
danmarklinman
Hi, it’s not the actual couplers catching the buffers is it? It has happened to me in the past, and it turned out to be that!! No more problems after I removed the top part of one coupler. Not ideal I know. Those me close couplers from Marklin may be an answer to this.
P.S all the derailments were as you discribed. Or against only one design of Marklin loco, we’re the buffers are lower than there coupled with wagon?
Wiking model car Fan
Instagram: marklin1978
Wiking fan
#11 Posted : 20 January 2022 20:09:04(UTC)
Thank's Dan! I checked that all the buffers are pushed all the way in. They were. I think it's the colder ambient temperature. Yesterday it was 20 degres warmer outside and they didn't derail at least in one direction. Now today it's colder again, and they are derailing on R3's, but not R2's. I applied synthetic lube on tuesday, and it was thicker than in summertime. My basement is 7 to 10 degres coolere than my main floor.
#12 Posted : 21 January 2022 07:44:12(UTC)
danmarklinman
You will just have to persuade your loved ones to move it into the dining room to keep warm, like me 😆😆😆Not sure how I managed that to this day. 🤔😁
Wiking fan
This page was generated in 0.499 seconds.
