Offline Maurice
#1 Posted : 15 January 2022 02:27:13(UTC)
Maurice
I have a couple of old 4081 Silverfish carriages and would like to know how the lighting works as l want to transfer lighting from a worn carriage to a better example that lacks lighting. One has a wheel set with rubber tyres and a small “plunger” - what does this do? I assume it changes tail lighting from white to red.
Any hints on how to get this working or a diagram would be much appreciated. At this stage I can not get the lights to illuminate but have not tested the bulbs.
Thanks, Maurice.
#2 Posted : 15 January 2022 05:12:40(UTC)
The 4081 is a coach with pilot compartment, so the contraption you mention is likely to change the lights depending on the direction the coach is moving.
See here: https://www.marklin-user...osts/t32781-Marklin-4081
Offline Maurice
#3 Posted : 15 January 2022 21:10:48(UTC)
Maurice
Thanks Mike, much appreciated.
Maurice
This page was generated in 0.201 seconds.
