Offline IBtrain
#1 Posted : 14 January 2022 20:13:45(UTC)
IBtrain
Nico Teering designed and developed the DCCNext based on an Arduino.
Does anyone have any advise/tips on how to have DCCNext
DCCNext web site
switch a Marklin Turnout?
In his manual
Mardec manual
he has two options;
1) is to use MOSFETs to control the turnout
here the MOSFETs uses DC volts to switch the turnout.
Problem; not only does Marklin use AC volts but the Marklin yellow wire is also connected to one side of the small lantern and the other side to the brown "O" on the rails. Would this cause a short circuit?
2) is to use a relay. Here the relay is used to power the frogs.
I tried connecting the brown "O" AC volts, to the center pin of the relay and one of the blue wires from the M turnout to the normally open on the relay and the same on another relay for the second blue wire. But I was not having success, the relays were cycling back and forth a few times and then would stop. I was using DC volts to power the relays (i.e. the lower part of the relay in the photo.)
Any help or advise would be appreciated
Kai.
Edited by user 03 February 2022 05:57:25(UTC)  | Reason: Not specified
Marklin K-track, Ecos 50200, RocRail
#2 Posted : 14 January 2022 20:26:42(UTC)
for the case of AC with mosfets why not run the supply through a diode so it is half wave rectified?
or use a DC source.
Offline IBtrain
#3 Posted : 14 January 2022 21:43:36(UTC)
IBtrain
or use a DC source.
Hi Dale
Thanks for the reply.
I only know the basics of electronics so pardon my ignorance.
For the MOSFETs you are saying use a diode on the brown "O" wire and another diode on the red "B" wire (from a Marklin transformer) before they connect at the GRD and VIN pins on the MOSFETs?
I imagine the direction of the diode is important?
In Niko's diagram, do you know why there is a diode connect between the V+ and V- before going to the solenoid?
About using a DC source, my concern is the internal wiring of the lantern.
If I use a DC source to the MOSFETs I thing I would have to cut the yellow wire before it connects to the lantern or else it would get two sources of volts.
or am I not understanding it correctly?
Kai
#4 Posted : 15 January 2022 03:56:34(UTC)
The yellow and brown wires would be what you use to power the MOSFETs
Here is what I was thinking to let only the positive half of the AC signal through:
Yes, the orientation is important.
If you are new to electronics, I suggest reading through the guide I made for using LEDs at
https://cabin-layout.mixmox.com/2019/10/modelling-with-leds.html
as it goes over the fundamentals of the diodes and rectifying the AC current that you need here also.
The incandescent light in the turnout lantern is not a full short, it either has enough resistance (being an incandescent) or has a resistor if it is a LED type. However, since current is only supplied during switching the light will be off most of the time, unless you isolate it from the yellow wire and feed it power separately.
I think the diodes across the MOSFET outputs are there because they are driving coils in the turnout, and the coils send a reverse pulse back after switching, so typically one places a diode across the coils to direct the reverse voltage to the other pole. It is commonly called a flyback diode.
Offline IBtrain
#5 Posted : 15 January 2022 07:21:20(UTC)
IBtrain
Hello Dale
Wow this is great.
This looks like something I can do. Adding the drawing really helps a lot.ThumpUp
I read through your link, great information, lots to take in Confused but you explained it very clearly. (I hope there is no test Laugh )
Thanks for sharing that.
What I don't fully understand is why does the red wire only need a diode. Doesn't the black (ground wire) also cycle but in the opposite phase to the red wire? It seems like from your drawing the black (or brown wire) remains 0 volts and only the voltage in the red wire cycles between +16 and -16 volts.
That's clear about the flyback.
If I do want to keep the light connected and on all the time, is there not a way of having the blue wires from the solenoid contact the brown (ground) wire through a relay as in the other setup? If the brown wire just remains 0 volts (i.e. ground or massa). It should work for AC or DC, but I must be missing something?
Thank you for your input.
Kai
#6 Posted : 15 January 2022 17:12:18(UTC)
I think a single diode will stop the reverse flow as the whole thing is a circuit. You can add one in the ground wire too if you like, it will reduce the voltage by another 0.6V
The "0V massa" label may be a bit confusing - in AC it will actually be -16V and all voltages are only relative to something else... so may diagrams label something as 0V but it just means other DC voltages are relative to that...
In my layout I uses a common "ground" and my digital and 16V AC are all relative to that. (In fact I think my house is also on that same ground!)
I don't know if a MOSFET can handle AC power, I have never tried that or looked it up. There is one way to find out!
There is an important bit of information you need to find out about the output from the DCCNext module... - does it hold the power on all the time or does it produce a momentary power blip?
Assuming the module is putting out a short pulse, I suspect you will need to isolate the light circuit from the MOSFET outputs. I think the MOSFET will remove both positive and negative power after switching. If it holds power on all the time for one or the other turnout directions, it will probably burn the Märklin solenoid out! But the light will stay on!
Test that with a voltmeter or small light.
And yes, there is a test - you will test your new knowledge yourself. If you get smoke you failed :-) (or had a bad teacher)
BTW just last week I implemented a pulse output for RemoteSign ESP modules designed for switching turnouts, etc. The software is working but I have not physically tested it on a turnout. I think relays would be a good way to go as they can switch on and off again after 100ms.
Offline IBtrain
#7 Posted : 16 January 2022 06:33:52(UTC)
IBtrain
Hi Dale.
Thanks for all this info.ThumpUp
I'll have to look it over in the next few days and get back to you.
Not looking forward to the test, but got my fire extinguisher ready...Scared
Kai
thanks 1 user liked this useful post by IBtrain
Offline IBtrain
#8 Posted : 03 February 2022 05:55:34(UTC)
IBtrain
Last week I was successful in getting the DCCnext to control Marklin turnouts which have the small lanterns connected to the solenoid.ThumpUp
Since the "common" of the light is hard wired to the rails i.e. brown wire "O" and the yellow wire goes to both the light and the solenoid then you MUST use AC power to control the turnout. Therefore you can not use MOSFETs since they only work with DC volts.Scared
If anyone wants to how I set it up, let me know and I'll post it.
Thanks for all the input,
Kai
#9 Posted : 03 February 2022 20:38:49(UTC)
Kai
There is no reason why you couldn't open the turnout mechanism and seperate the yellow wire going to the lamp from the common connection on the coil. A seperate supply can then be used for the lamps and the coil can then be supplied from the DCCNext, allowing use of the MOSFETs.
Offline IBtrain
#10 Posted : 04 February 2022 04:18:57(UTC)
IBtrain
Kai
Hello KiwiAlan
That is true. But that does involve a few more steps, plus getting at the turnouts that are already installed on the layout.
This page was generated in 0.372 seconds.
