Offline Dfergus54
#1 Posted : 01 January 2022 14:54:57(UTC)
Dfergus54
I am new to Z scale. I bought a starter set and E and T1 extension sets. I can’t figure out how to power the 72720 control box.
Offline Carim
#2 Posted : 01 January 2022 16:11:51(UTC)
Carim
See the attached document:
Wiring 72720.docx (981kb) downloaded 94 time(s).
Carim
Offline Dfergus54
#3 Posted : 01 January 2022 16:43:40(UTC)
Dfergus54
Carim
Thank, Carim.
What is the purpose of part 72090 that also comes with the extension sets?
thanks 1 user liked this useful post by Dfergus54
Offline Mman
#4 Posted : 01 January 2022 17:29:06(UTC)
Mman
72090 is a distribution strip which allows you to join together various wires like common returns such as all the yellow wires connected to points and signals etc. Because these plates can be screwed to the baseboard it enables a neat and methodical way to accommodate the wiring.
You could just as easily (and much cheaper) use terminal strip sometimes called chocolate strip to join wires in screw terminals.
ChrisG
Offline Nightowl999
#5 Posted : 15 January 2022 00:25:28(UTC)
Nightowl999
I found using the terminal blocks to be quite awkward, requiring the connector plates to be bent closer to a right angle to allow the plugs to be plugged in to it.
Chocolate blocks are a better idea, but the cables supplied with the accessories is a bit delicate, so my preferred option would be something like this or this.
Wago make really good quality connectors, but they're much more expensive and would probably be over-kill for the low voltage of model railways!
Hope this helps..
thanks 2 users liked this useful post by Nightowl999
This page was generated in 0.242 seconds.
