Offline michelvr
#1 Posted : 20 December 2021 20:26:49(UTC)
michelvr
I thought to present to you my $10.00 Canadian solution for my platforms for my Hamburg station!
This picture is only showing you less than half of the platforms but you should get the picture. My platform slabs are half inch high by six inches long by three and three quarter inches wide. You’re seeing then in the flesh so they’re a little pink and embarrassed to be seen! I told them I’m only going to take one picture and I promised them the next pictures will be done when they’re attached and fully painted!
So no more embarrassing pink foam, please! 🤣
I could not have done this without my Proxxon foam cutter! Can you believe it, I can cut very thin strips perfectly straight down to one sixteenth of an inch and up to a foot long without any blemishes. Half inch, inch and two inch thick pink styrofoam can be shaped without any hassle!
$10.00 Canadian buys you one sheet of pink styrofoam and it’s half inch thick by two foot by eight foot.
thanks 6 users liked this useful post by michelvr
#2 Posted : 20 December 2021 21:23:04(UTC)
That's a Vollmer Baden baden station, but you can call it Hamburg.
#3 Posted : 20 December 2021 21:24:49(UTC)
Look good.
Why cut them to 6" lengths if the cutter limitation is 12"?
Offline michelvr
#4 Posted : 20 December 2021 23:11:43(UTC)
michelvr
Look good.
Hi Dale,
I tried twelve inch lengths but it didn’t look as realistic as the six inch pieces do. They now look like prefabricated platform slabs that were placed there by a crane. Too bad I don’t have a Märklin Goliath to put it into perspective.LOL
thanks 2 users liked this useful post by michelvr
Offline michelvr
#5 Posted : 20 December 2021 23:39:52(UTC)
michelvr
Cool I thought the same thing!LOL
#6 Posted : 21 December 2021 22:42:47(UTC)
Wow- foam is much cheaper in Canada than the USA!
#7 Posted : 21 December 2021 23:36:27(UTC)
Must be regarded as a medication.
#8 Posted : 22 December 2021 00:15:31(UTC)
3 x 3 ft. Squares $6 at Menards.
Offline michelvr
#9 Posted : 22 December 2021 02:52:00(UTC)
michelvr
Offline michelvr
#10 Posted : 22 December 2021 02:57:55(UTC)
michelvr
BigGrin
FOAMULAR C-200 XPS Insulation 24-inch x 96-in
Overview
Model # 270367 Store SKU # 1000436411
FOAMULAR Extruded Polystyrene (XPS) Rigid Insulation is made in Canada and offers a combination of characteristics that result in long-term thermal performance of R-5 per inch, compressive strengths of 20 100 PSI and exceptional moisture resistance. Using FOAMULAR insulation can create comfortable living spaces in basements, as well as minimizing heat loss or gain when using it on above-grade exterior walls and the interior of foundation walls. FOAMULAR XPS Rigid Insulation is lightweight and durable making it easy to handle, saw, cut and score.
Used for above/below grade exterior walls, basement interior walls or basement floor slab
Moisture-resistant
Long-term thermal resistance
R-5 per inch of thickness
Minimum 20% recycled content, SCS Certified
GREENGUARD Gold certified for indoor air quality
It doesn’t say anything about medication so please don’t get any ideas of inhaling, ingesting or smoking it! LOL
#11 Posted : 22 December 2021 03:15:51(UTC)
It's basically homosote. Home depot only had it online back in summer.
Offline Crazy Harry
#12 Posted : 22 December 2021 03:54:18(UTC)
Crazy Harry
The pink stuff is extruded polystyrene, homasote was/is a pressed paper product. I haven't seen homasote for sale in Canada for a long time. It was great for layout baseboards and backstops behind dart boards!
Harold.
Offline michelvr
#13 Posted : 22 December 2021 21:10:50(UTC)
michelvr
Update -
Cursing
Confused
Crying
I’m almost foaming at the mouth! Scared
Well so much for pink styrofoam as a medium for platforms Blink
After I assembled them together I didn’t get that 🥰 feeling so….
….back to using what I know works best!
Balsa wood Wub
To be continued…..LOL
This page was generated in 0.592 seconds.
