Offline Chris6382chris
#1 Posted : 12 December 2021 03:30:05(UTC)
Chris6382chris
Good evening.
I am operating an ECOS Command Station, Hardware Version 2.0, with Firmware update version 4.2.8. When looking at Operation Settings and looking at my internal booster (don't have an external booster) the temp reading for my ECOS eventually climbs to about 78C (after about an hour of running trains). Is that normal?
Would appreciate any feedback from other ECOS users.
Chris
#2 Posted : 12 December 2021 06:45:03(UTC)
What is your ambient temperature?
#3 Posted : 12 December 2021 07:38:43(UTC)
You sure its 78° C ? this is almost boiling point (100°C)., however 78°F would be about 25.5°C and this temperature would be exceptable
#4 Posted : 12 December 2021 12:01:49(UTC)
Chris6382chris
The room temp is very mild 69F. But the temp reading on the ECOS reads 78C, to be clear this the internal booster reading. I agree about the boiling point comment and 78C being so hot that is that is why I was shocked to see it.
When I turned it off for about 20 minutes and then turned it back on it read 39C. After 20 minutes of use it climbed back up and stayed at 78C.
The outside of the unit on the bottom is slightly warm to the touch but nothing unusual. Someone on the ESU forum said that was a normal reading, but to me it seems high. I was wondering what others saw on their ECOS after 30 or so minutes of usage.
I have about 40 digital engines on the layout. I only run 4 at anyone time, all using LEDS, and done with sound. The other36 engines are sitting, lights off waiting for their turn. I do not have an external booster. I will start removing engines and see if the internal booster temp drops. I’ll also look to see if the ecos has vents for air circulation and see if those are clogged.
Thanks, Chris
Offline Zosch
#5 Posted : 12 December 2021 12:58:57(UTC)
Zosch
Hi Chris,
Yes, it is normal because the temperature is measured directly on the new booster output stage, so you have different temperature values ​​compared to the old ECOS!
Regards from Switzerland
Roland
www.reichs-bahn.ch
http://reichs-bahn.ch
Corresponding in English and German
#6 Posted : 12 December 2021 15:44:45(UTC)
Chris6382chris
Thanks for the response. That’s reassuring but wow that seems hot.
#7 Posted : 12 December 2021 20:50:56(UTC)
Something is wrong here.
The system should be shut off automatic if the temperatur increase more than 45 C°!!
There is a cooling element that will shut the system off if it overheat.
#8 Posted : 12 December 2021 23:53:38(UTC)
Chris6382chris
Hi Goofy. Thanks for responding. When you look at the manual for the ECOS you will you see that an image of the current monitor and in that image it shows at least 50C so I don't think you are correct about it shutting off above 45C. Also, as pointed out above, after the firmware updates the temperature is now measured directly with the new booster power amplifier. I honestly don't know what that means but it seems to mean something.
If my ECOS was truly 80C which is what the internal booster temp is showing me, I would think my ECOS would be very hot to the touch. It is only mildly warm if I place my hands directly on the screen or under it, similar to a laptop, but not even as warm. The sides and dials are cool to the touch.
I have now been running trains for almost 2 hours as a test and the temp for the internal booster has maxed out at 80C and stayed there and as I have said earlier I have 40 plus engines and some lighted (LED) coaches on the track and have been running four trains the whole time, one on the mainline (with sound) and three using the shuttle function of the ECOS.
I have not had any issues or problems. Also, I have set my transformer to about 18.1V. I continue to show about 2755 mA of 3580mA being used.
I know I started this topic by saying I think my Ecos is running hot but now I think it might be normal. Can any other ECOS users that have all the firmware updates please tell me what your temp is reading for your internal booster.
Chris
Offline Donb
#9 Posted : 13 December 2021 03:39:03(UTC)
Donb
Chris
Hi Chris,
Why not sign up to the ESU support Forum and ask there?
https://www.esu.eu/en/forum/forums-overview/
Don
Best Regards,
Don
IB 2 and MFU modul, C track and Z scale, mostly DB/DR and SBB, SJ
#10 Posted : 13 December 2021 04:02:57(UTC)
Chris6382chris
Hi Don. I have and am waiting to here back. I just thought I’d check on here as I know many people use the ECOS.
And I think Roland has the answer. It has to do with a firmware update. But I just wanted to hear from ecos users to see if they experienced the same.
Chris
#11 Posted : 13 December 2021 09:32:24(UTC)
Chris
Did you try to touch the Ecos if there is unnormal high heat?
If so you have serious problem about your Ecos.
In fact shall the system shall shut off if there is overheat.
#12 Posted : 13 December 2021 18:10:49(UTC)
Chris6382chris
Chris
Hi Goofy. The unit isn't hot to the touch. If anything the unit feels like a laptop computer but not even that hot.
#13 Posted : 14 December 2021 05:48:54(UTC)
It is possible that you read with Fahrenheit instead that the symbol should stand F and not with the C.
#14 Posted : 14 December 2021 14:02:36(UTC)
I don't know about the Ecos but on my CS3 a temperature from 25°C up to 50°C is normal (also the same on my 2 CS2s). My CS3 is used with a 5 A current output.
So I believe a temperature of 70°C or more, is not normal. Of course, the Ecos or CS3 must be installed on a flat hard surface allowing air convection for cooling.
Question: When you start your Ecos what is the temperature reading? It may be that the temperature reading component is lousy.
#15 Posted : 14 December 2021 20:06:41(UTC)
Chris6382chris
Hi Jean. The ECOS starts at room temp and then climbs as it is used over time to the 78-80C reading for the internal booster. I have checked on the ESU site and people on there assure me it is normal as it is reading heat generated as described in my previous posts.
I have ordered an ESU 7A booster. So we will see what that reads when installed ans how that impacts the builder in 4A booster of the ECOS.
#16 Posted : 14 December 2021 23:10:25(UTC)
This certainly the order of temperature I would expect to see at the chip while operating at ambient air temperature. The thermal resistance between the chip and air is quite high - this is why things that dissipate a lot of heat have big lumps of metal to conduct the heat away, and then have lots of fins to convect that same heat into the air, and why things that have serious heat dissipation have fans that move a lot of air.
#17 Posted : 14 December 2021 23:28:54(UTC)
Maybe it has built in heating to keep the train room warm in winter.
#18 Posted : 15 December 2021 00:08:58(UTC)
Chris6382chris
Indeed, an additional heat source for the basement. It seems to be running fine and nothing has melted so I am going to go with it is normal and leave it at that. I appreciate the feedback I received. Thank you.
Chris
thanks 1 user liked this useful post by Chris6382chris
#19 Posted : 26 January 2022 07:04:02(UTC)
Being Australia Day and bugger all meat for the BBQ available thanks to COVID, I got to run the trains today.
The train room is set at 23C with a low humidity of 45% (for this part of the world) and the eCOS 2 reads 52C with version 4.2.9 installed.
#20 Posted : 26 January 2022 16:24:19(UTC)
Chris6382chris
Thanks for this feedback. I am going to install the new firmware update later today and run some trains so I will see what kind of readings I get.
Thanks again.
Chris
Offline Donb
#21 Posted : 26 January 2022 22:07:39(UTC)
Donb
I have only had my new 50210 for about two weeks, after fixing an issue with a Viessmann brake module that was giving RailcomPlus fits, its running pretty good.
HW 2.1.1
SW 4.2.9
Running two trains with lights, sound etc drawing about 470mA avg for about an hour temp is 52C.
Best Regards,
Don
Guest (4)
This page was generated in 0.589 seconds.
