Offline Joakim_B
#1 Posted : 24 November 2021 11:37:56(UTC)
Joakim_B
Hi Märklin friends
After updating of my CS3 and CS3+ (to 2.3.1) I often have the message in German: Der decoder wird ausgelesen”, but only when some trains is moving with sound turned on. The message disturbs the S88 readings and the system has further error messages.
By reading German forums I found out that the M83/84 may cause the problem and if I disconnect the M83 (mfx) on my layout the fault is gone! But how can I eliminate this error/fault?
If anyone knows about this issue and have good suggestions I’ll be happy BigGrin
Joakim
Edited by user 30 November 2021 15:58:03(UTC)  | Reason: Not specified
#2 Posted : 24 November 2021 21:23:58(UTC)
Hi Joakim,
I think I get a similar reaction on my old Mobile Station 1 (60652).
The graphics for the speed control just flash, indicating that particular engine is no longer detectable by the controller.
On my layout this is caused by dirty track.
Offline Joakim_B
#3 Posted : 25 November 2021 09:28:47(UTC)
Joakim_B
Hi Kimball - and thank you. I do not think that that the issues are the same. The messages and the faults are there even when the trains are not moving
Br Joakim
thanks 2 users liked this useful post by Joakim_B
#4 Posted : 25 November 2021 12:28:24(UTC)
Is the m83 functioning correctly? Could you possibly be running a locomotive at the time the error shows which has the same address as the M83? Wether mfx, or mm format?
I had a locomotive with a mm format address 01. It was changing an mfx home signal when I set the f4 function on. The cs3 assigned address 01 for the home signal upon mfx install. Now the cs3 is supposed to separate addresses for locos, signals, and turnouts. It could be a fault with the signal decoder, but changing the locos address to 02 stopped it.
Offline Joakim_B
#5 Posted : 25 November 2021 16:32:40(UTC)
Joakim_B
Hi M5999
Your proposal is very interesting. I have never considered that some addesses for M83 (mfx) could be the same as some loco. .. I have now checked and one old M6080 decoder has the same mm addres (41) as one of the M83!
It is now changed and I'll investigate further and be back.
#6 Posted : 25 November 2021 17:36:49(UTC)
Hi Joakim
Just a shoot in the dark about your problem.
I have quite a number of MFX locos on my layout (32 all on line). When I update the CS3 (was the same with a CS2 60215 previously), I have to "short-register" the MFX locos again.
Short register: you have to select each of your locos on the CS3 and now the loco is fully in line with the CS The MFX number does not change but it looks like the procedure is only then fully completed. Alas I would prefer that registered MFX locos would stay on-line and they do except after a new update.
Note: I have a few MFX accessory decoders but avoid using MFX on them.
Another function that works quite well with the CS3: find lost MFX locos. It used to be crap on the CS2 with earlier versions.
I believe Märklin is still having some issues with MFX (the locos are not all the time in line (I use Rocrail) and the locos are supposed to have sounds ON (the CS3 says it is on) but I need to toggle the command to have it transmitted to the loco (not a real problem with Rocrail. This is just an example but it shows Märklin MFX bugs are still remaining.
Offline Joakim_B
#7 Posted : 26 November 2021 17:07:03(UTC)
Joakim_B
Thank you Jean!
Also a very interesting and useful tip. I'll investigate all and I'll be back, when I find the root cause for the strange behaviour ......
By the way, how do you avoid using MFX on MFX accessory decoders ?
Cheers and have a nice weekend
Joakim
#8 Posted : 26 November 2021 20:26:40(UTC)
Hi Joakim
What I do (e.g. on a 60832) is I use the switches to set the address associated with a manual creation on the CS3
Inspection of the MFX registration of the same module on the CS3 and deletion of the unused registration (if any).
Note: The accessory decoders register only when you select the function “Find New mfx Devices”
This is where a separate wiring for rail and for decoder can help prevent unwanted registrations (you select this function only to find locos while the accessory decoders are not powered)
#9 Posted : 26 November 2021 21:15:24(UTC)
Thank you Jean!
Joakim
The mfx funtionality is only used to report the address to the controller, or to set up an address. Once that is done then the address used to operate the device is the MM or DCC address as set on the switches or configured by mfx.
#10 Posted : 26 November 2021 21:47:52(UTC)
Hi Alan
In theory you are right - so simple - I believe there much more complication:
- interrogation of loco MFX addresses with possible multiple answers in the same time slot
- arbitration between address conflicts
- re-use whenever possible of the loco own MFX address
- reprogramming of new MFX addresses
- avoiding the re-use of loco's addresses recently seen by the CS2 or CS3 (temporarily not on the layout or in stop sections
- manage important noise levels for decision (on a simple layout MFX works like a charm but it gest more complicated when many locos are in place)
So this is why, Märklin has troubles finding the last bugs. But the system has vastly improved since the early CS1 (60212) and MFX models in 2006 or so
#11 Posted : 26 November 2021 22:25:24(UTC)
Hi Alan
Ah, ah, no, I'm talking about mfx accessories, i.e. signals and points, not locos. Locos and other mfx rolling stock always operate as an mfx device and use the mfx address. Accessory devices only use mfx for identification during start up, and then use the MM or DCC address.
Offline Joakim_B
#12 Posted : 30 November 2021 15:56:16(UTC)
Joakim_B
Dear group
Thank you for your supporting inputs!
After a long investigation I’m happy to inform you about that the issue now is solved.
One of the M83 (60832) was obviously defect and from time to time disturbs the network so much that the CS3 stated “Der decoder wird ausgelesen” and at the same time declared the S88 lines defect. After replacement of the defect M83 and also the establishment of a dedicated two wire line to the M83 inputs the problem has disappeared!
Have a nice and happy December
Joakim
#13 Posted : 30 November 2021 22:13:17(UTC)
Wow! I'm curious, had the defective M83 ever make odd beeping sounds, either steady or intermittent? I have an old hobby M track turnout with a bylb mantern connected to one, and depending on the turnout's position does this. It hasn't yet caused any problem.
#14 Posted : 30 November 2021 23:05:29(UTC)
The old style M83 (6083) with discrete components are easy to repair There is a later generation 6083 with SMDs (Surface Mounted Devices) which call for specialist equipment (hot air regulated gun) harder to repair.
The problem with 6083 is there is no fail-safe arrangement: they are waiting for the order coming from the CS1, CS2, CS3 or 6020 or 6021 to shut off the solenoid.
If this order is garbled (because of electrical noise or short c.) then the solenoid remains ON until the solenoids burns and becomes a short circuit which in turn burns the output transistor of the M83.
On newer decoders (60832, 60831) the solenoid is switched OFF no matter what after 500 mS. When programming a longer activation time (up to 5 s I think), the unit switches OFF every 500 mS and is then restarted thus sounding like a submachine gun
The advantage of these older units (6083) is that they could drive a 7051 crane just like that (as long as you push the button, the motor turns) which the newer 60831 or 60832 can't.
Sorry for the long explanation
Offline Joakim_B
#15 Posted : 01 December 2021 09:12:26(UTC)
Joakim_B
Hi M5999, No, but I noticed that it emitted more "electronic sounds" (no beeping) than the other devices. My guess is that it was a "Monday production fault". But interesting that the fault was only present when locomotives vere active and with sound turned on. Confused
thanks 1 user liked this useful post by Joakim_B
#16 Posted : 01 December 2021 12:43:58(UTC)
Thanks for the explanations Jokam, and Jean! Mine are the newest ones.
Each Marklin Digital device includes an FCC for the USA notice that they can not interfere with certain military, municipal, or other govt. Frequencies.
Thus, they must be vulnerable to certain interference from those frequencies. So, could some also interfere with each other?
Just a thought.
Offline Joakim_B
#17 Posted : 01 December 2021 13:30:52(UTC)
Joakim_B
Just a thought.
Hi again BigGrin
I do not believe that the interference are airborne. It is purely on/in the power/data lines.
Have a nice 1. December
#18 Posted : 01 December 2021 14:23:03(UTC)
Views messages in topic : 15,594
Not all Märklin items come with FCC approval. In some cases the manual indicates that the customer must obtain FCC approval for that item.
#19 Posted : 01 December 2021 15:08:57(UTC)
Thtat's how they cover themselves from the US Pentagon should any trouble arise. It shifts the burden of responsibility to the US consumer.
This page was generated in 0.652 seconds.
