Offline Kanga
#1 Posted : 12 November 2021 20:38:46(UTC)
Kanga
Hi Team,
I've done a search for an archive of CS3 software updates, both here on the forum and on the Marklin website, but not come up with anything.
Firstly, has anyone ever had an issue with a software update and intentionally reverted back with no problems and secondly is there an archive of these updates?
Karl
thanks 1 user liked this useful post by Kanga
#2 Posted : 12 November 2021 21:55:21(UTC)
Not really. The last big one had a few glitches, but Marklin issued a patch immediately. Some have done forced updates, but it is tricky. You can reset the CS3, but you lose all your locomotive rosters. Not sure about toher data if backed up. I'd wait until Marklin service responds.
#3 Posted : 12 November 2021 21:57:35(UTC)
Originally Posted by: Kanga Go to Quoted Post
Hi Team,
Karl
There is no archive of updates, but there is a means to force an update, which I think is what you need to do.
I think (but you need to check) the procedure is to have the cs3 connected to the internet, turn it off, hold down the left hand knob and the stop bar while turning the power on.
I don't understand why you have opened a new thread over this.
#4 Posted : 13 November 2021 05:25:26(UTC)
There is no official archive of updates but I have copies of versions
1.2
1.3
1.33
1.4
2.0
2.31
Are any of those of use?
Offline Kanga
#5 Posted : 14 November 2021 04:05:06(UTC)
Kanga
From reading the changelogs, it would seem version 1.33 would be a good place to start. I'm tempted to go just one version back and see what happens as well.
Karl
#6 Posted : 14 November 2021 08:46:46(UTC)
What version are you currently using?
Offline Kanga
#7 Posted : 14 November 2021 22:36:27(UTC)
Kanga
I carried out the upgrade to 2.3.1 and have issues with the display not getting any further than the "splash page".
#8 Posted : 15 November 2021 00:09:31(UTC)
Have you tried the force reload I suggested? I haven't seen any message to say you have.
I don't see any sense in trying to back to any previous version because i don't think it will fix the problem.
#9 Posted : 15 November 2021 03:35:06(UTC)
Try the force reload first, if that doesn't work I can upload some older versions to dropbox for you.
Offline Kanga
#10 Posted : 15 November 2021 07:24:20(UTC)
Kanga
If by forced reload, you are referring to the process of inserting the USB with the 2.3.1 software update on it and/or having it connected to the internet and holding down the stop bar and left stop button (speed control) then yes, I have done that several times using both USB and direct internet connection with the same result.
#11 Posted : 15 November 2021 10:46:06(UTC)
Could restarting the CS3 apps possibly help Kanga? Resetting it to factory empty state?
Online bph
#12 Posted : 15 November 2021 12:16:31(UTC)
If you have not tried it yet, try to disconnect everything from the cs3, track, accessories, USB, SD cards etc.
you can also try a forced update while everything is disconnected. (except the update source, but try different options separately)
And of course, you could try the Märklin service phone in Germany, they speak English (at least one or two).
and as a side note, there is rumored to be a CS3 update before Christmas.
Offline Kanga
#13 Posted : 16 November 2021 01:58:24(UTC)
Kanga
I started up the CS3 just now after unplugging the track. I had already unplugged the MS2 at the beginning of all this mess and the track was the only thing left plugged in although there were no locos or other address components on the layout. I still have the same issue but this time I got a lot of white screens during the boot sequence - then the same screen.
My emails to the service address bounced back - after 4 days. I have resent them after checking the address spelling.
Karl
Offline Kanga
#14 Posted : 18 November 2021 23:22:59(UTC)
Kanga
An update. I was given a copy of software update version 1.4.1 (sincere thanks to that person), carried out a forced update off a USB and have restored the operation of the CS3. All the locos are still in memory and it is now working fine. I may wait for another software version past 2.3.1 to be released by Marklin before carrying out another update.
Karl
thanks 2 users liked this useful post by Kanga
#15 Posted : 19 November 2021 00:28:56(UTC)
Excelent Karl! Glad it's fixed!
This page was generated in 0.444 seconds.
