Offline Puttputtmaru
#1 Posted : 01 October 2021 23:09:09(UTC)
Puttputtmaru
Hello all, I am still in the planning stage for my layout after many years out of the hobby.
I am debating if I should use 2265/6 turnout or the 227815/6 turnout. I will be using ESU servo control on them.
1) Which do you recommend? Advantages disadvantages?
2) is there a problem down the line to have a 64.6 mm spread or a 57mm spread between rails, which each turnout leads to, for curves?
Offline PeFu
#2 Posted : 02 October 2021 15:56:52(UTC)
PeFu
If you have the space, for the better looks, I strongly suggest the 22715/22716 turnouts. I only use a few 2265/2266 in hidden areas. Track distance of 57 mm also looks great, however this is also a matter of available space; Depending on your rolling stock, you may need wider curves based on flex tracks.
Smile
#3 Posted : 02 October 2021 16:14:51(UTC)
Puttputtmaru
Smile
I am planning on using mainly flex track so that would not be a problem. Great idea to use the 2265/6 in hidden areas actually was probably planning on using c track too there too.
I was just concern about passenger train touching in curves with the 57mm spread!
Will I be limited for some options and flexibility of the layout?
#4 Posted : 02 October 2021 16:32:56(UTC)
As pefu says; The slim turnouts are definetly the way to go. Not only for looks, but also they give safer running (less problems for the rolling stock, S-curves, other brands wheels, etc).
#5 Posted : 02 October 2021 20:56:04(UTC)
Puttputtmaru
Ok thank you guys, I will follow your advice.
This page was generated in 0.359 seconds.
