Offline Pengouin
#1 Posted : 08 September 2021 14:38:04(UTC)
Pengouin
I have an old Marklin DB Class V 200 locomotive. It is probably 60 years old and comes from my grandfather. It has been converted to digital 25 years ago with a MM decoder but the motor is very noisy and not very smooth. So I would like to renovate it.
I plan to use a LokSound v5 decoder but I have no idea what motor I should use. Marklin is selling some upgrade kit for motors. Are they good or should I look for alternative ?
I also plan to change old bulb light with LED. Do you know any kit I can buy with white/red LED ?
Any other advice ? It will be my first locomotive renovation BigGrin
Thank you for your help
thanks 1 user liked this useful post by Pengouin
#2 Posted : 08 September 2021 14:56:07(UTC)
Welcome! Does it have a 5 pole motor? If so, it may only need cleaning and oiling. These are not really quiet anyway. It's the gearing. The armature bearings tend to also ne noisy. They quiet down as heat from running warms them up usually. If you plan on ever using a CS2 or 3, I'd stay with Marklin mfx. Of course you can use them with an ESU Ecos as well.
You'd need to maually enter a Loksound decoder on a CS2, or 3 as DCC or MM. You can order a marklin led parts for a newer V200 for for the front and rear. You will need resistors so they don't flicker. ESU may also have them.
#3 Posted : 08 September 2021 15:10:27(UTC)
There are LokSound decoders that support mfx and will register automatically. Many Märklin locos were sold with factory-installed ESU LokSound decoders before/while Märklin developed the MSD.
Offline mvd71
#4 Posted : 08 September 2021 23:10:47(UTC)
Märklin 60944 is the correct kit for this model to give smooth and quieter running with the new decoder.
However if you want the quietest option and cost is not an object, check out the offerings from SB-Modellbau.
Cheers….
#5 Posted : 10 September 2021 06:12:24(UTC)
There are several things to look out for:
a.) yes a 60944 high efficiency motor
b.) ball bearings on each side (front 4mm x 1.5mm x 2mm), rear: 5mm x 2mm x 2mm), how ever you need a tool to do this
c.) make sure the brushplate brushholders are resting on the brushplate and aren't raised (this also makes the loco run rougher and slower)
d.) Led's: this is a personal choice, whereas you drill holes for the marker lights and insert 2 leds: 1 white, 1 red or you can use the current bulb holder and get an insert into the bulb holder and use a led's white/red, the insert led holder has 2 holes for the led's and has also 2 empty holes whereas you can put the 3rd wire through, you need 2 resistors (1k),
e.) with the loksound 5 you have 2 options I would recommend: 21 mtc adapter plate or a Plux 22 adapter plate. ( it gives you 8 Aux functions) whereas the 8 pin will give you 6 Aux functions ( but you need an 8 pin wire harness for it.
f.) you can also add 2 cab lights but when you do this I would recommend you fit the Led's head/marker lights onto the housing and use a plug whereas all the wires from the led's (head/marker and cab lights are combined) and use a spare spot on the frame where you can fit the socket.
g.) there is heaps of room for the cube loudspeker
h.) choice how to program the cab lights: use the Aux function to be inserted at the "stop" for forward and reverse,
i.) use the light function: neon light, and add a cut off time for the cab light (when the loco stops the cab light will come on and when the loco is in motion the light will go off depending on the timer.
j.) motor room light could also be incorporated with the head/marker, cab lights.
k.) progtramming the motor: under motor you have a variety of different motors: use the Märklin highefficiency motor or leave it at default settings.
l.) to have a slow start reduce the minimum speed from 3 to 1
m.) if you want to go ahead with the ball bearings I could do this for you but you would have to send me the motor and the brushplate (not the perm. magnet)
n.) or the choice of a Faulhaber motor (SB Modellbau)
Offline Pengouin
#6 Posted : 10 September 2021 22:33:13(UTC)
Pengouin
Thanks you all for those great advices.
I don't know if it's a 5 pole motor. I plan to disassemble it this week-end and I will check.
I have a Marklin CS2 but I use several Lok decoder for my Bemo trains. So I prefer to use then to update my Marklin locos has well.
I hadn't thought of spare parts. Thanks for the idea.
SB-Modellbau seems to have great motors. I didn't know about them. Thanks i will consider it.
Wow thanks John for the great answer. I will need some time to deal with all of this.
Have a nice weekend everyone.
Antoine
This page was generated in 0.475 seconds.
