Offline Johnvr
#1 Posted : 08 September 2021 10:27:01(UTC)
Johnvr
Hello all,
A friend of mine is constructing a large layout.
He is building the layout around the room and the layout will have 3 x Stations with passing tracks.
Signals will be placed at each of the passing tracks.
Circuit tracks are being used to trigger the signals to stop and go.
A representation of the layout is as per the attached picture.
How many trains can he run on this layout without one train catching up with the train in front ?
What is the scheduling sequence for operating these trains without collision ?
Where is the best place to insert the circuit tracks around the station area ?
We are not using 'occupancy blocks' , but do you think that 'occupancy blocks' would improve the safety of operations ?
He is operating using Central Station 2, with Marklin s88 feedback.
RegardsBigGrin
#2 Posted : 08 September 2021 10:57:51(UTC)
John, depends on the layout dimensions, train lengths, speeds,
Temperature of room, Motors, etc. Heat is speed.
I am poor in algebra, but the CS3 can stage events with delays.
One S88 has 6 inputs. It shows 6 signals. Unless he has a total of 12 circuit tracks, contact tracks, blocks, or reed switches, one should suffice.
Speeds of the trains can be set slower as well. It may be possible to run 3 at once. One can wait in the stations until another passes, but why not add two more turnouts and a through track?
#3 Posted : 08 September 2021 11:03:28(UTC)
A simple approach: five trains, never more than one signal showing green. Only one train running at any time.
With fewer trains there would be an option to have two (or more) trains running at the same time.
With two more signals in each reversing loop, there would be more options.
#4 Posted : 08 September 2021 14:51:21(UTC)
I agree with Tom, a signal on each end loop (even a virtual signal) with the end loops being inside tunnels to give the feeling of 'exit stage left/right, enter stage left/right, would help.
But I think you need more signals, one on the main line at the entry to each station so the main line sections also become signaled blocks will allow more trains to run at a time. I would also be tempted to double track between two stations so trains can run both directions simultaneously between those two stations, otherwise I think you will find that you will only ever have one train running at any one time as a block becomes clear in front of it.
#5 Posted : 08 September 2021 15:54:57(UTC)
Or a double track all around the layout with 3 tracks in each station, this would give you a heap of options where as you could also incorporate a shunting yard, there is always the risk you could get bored and you may change the configuration at a later stage., so why not do it now.
A shuttle service between station 1 and 3 is also possible
Offline Hannes Porsche
#6 Posted : 08 September 2021 23:20:06(UTC)
Hannes Porsche
Hi John. Nice plan and layout. !!!!!!!
To trigger more comments, not so simple --- I say only FOUR trains on the above layout.
HANNES
thanks 2 users liked this useful post by Hannes Porsche
#7 Posted : 08 September 2021 23:31:36(UTC)
With absolute certainty: 1 train. (So long as the train is shorter than the turning loops.)
Probably 4.
Offline mvd71
#8 Posted : 09 September 2021 02:56:22(UTC)
Five
Offline Johnvr
#9 Posted : 11 September 2021 10:13:35(UTC)
Johnvr
Thanks to everyone who has commented.
I am adding some pictures from the layout build to give you an idea on what we are doing.
The length of the layout from one reverse loop to the other reverse loop is about 100 metres long.
The layout winds around the attic of the house, through twists and turns, over bridges and around corners.
The station platforms as depicted in the diagram will be long enough for train lengths of 3.5 metres each.
We are building a staging yard for 8 trains of 3.5 metres each (the staging yard in the picture has been modified since the picture was taken)
There is a separate line for Bigboy, because Bigboy hauls about 80 wagons and the train length is about 30 metres long, and there are no crossings between Bigboy line and other mainline, for obvious reasons !
I am planning on running 4 trains easily on the mainline, with 8 trains rotating in the staging yard.
Bigboy will run on his own line.
thanks 5 users liked this useful post by Johnvr
#10 Posted : 11 September 2021 11:53:14(UTC)
Oh, it's large! Shouldn't be a problem keeping trains safely distanced with speeds closely sinked and signal blocks. I hope that attic is air conditioned though.
#11 Posted : 11 September 2021 17:05:05(UTC)
There is a separate line for Bigboy, because Bigboy hauls about 80 wagons and the train length is about 30 metres long, ...
US style 4-axle plastic body box cars (40 ft model):
15.5 cm x 80 = 12.4 m
US style 4-axle tin plate box cars (50 ft model):
18.5 cm x 80 = 14.8 m
I wonder: How long are the Big Boy and the trailing caboose that the train reaches 30 m in length?
RollEyes
Edited by user 12 September 2021 00:08:49(UTC)  | Reason: Not specified
Offline michelvr
#12 Posted : 11 September 2021 18:15:43(UTC)
michelvr
Hello John,
Now that’s a big North America themed layout! Drool
When it comes to running trains, the more on the tracks the more realistic it will be! At my friend’s Roger layout we usually run five trains and his layout is only a quarter of the length that I see in your pictures. Just like the real trains the more train that move good the more money the railroad makes. It’s also more fun when you have a busy layout!
Very impressive and once the long trains runs you’ll need this playing on the stereo!
Offline Johnvr
#13 Posted : 12 September 2021 13:37:16(UTC)
Johnvr
RollEyes
Hello AK
I think that you have a good point !
I got the figures wrong - wishful thinking Blink
I shall go there on Monday of this week, and I shall measure the length of the train as it is this week.
Here is a quick video with 60 wagons .. how long do you think that this train is ?
Bigboy train
Offline Johnvr
#14 Posted : 12 September 2021 13:39:04(UTC)
Johnvr
And another link to a video :
Bigboy train ver 2
#15 Posted : 12 September 2021 17:57:15(UTC)
probably 30 ft instead of 30m
Offline Jay
#16 Posted : 12 September 2021 19:56:32(UTC)
Jay
Bigboy train ver 2
Hi John, the links don't seem to work
#17 Posted : 12 September 2021 22:20:30(UTC)
Originally Posted by: Jay Go to Quoted Post
The links don't seem to work
Same problem here.......... Blink
Offline Johnvr
#18 Posted : 13 September 2021 14:57:21(UTC)
Johnvr
New video link :
Bigboy long train
thanks 4 users liked this useful post by Johnvr
Offline dickinsonj
#19 Posted : 15 September 2021 02:03:18(UTC)
New video link
Cool video John - thanks. Is that your 80 car consist you mentioned?
I have not run all of my US freight wagons in one train in a while, but my latest count is 81, including three cabooses. I guess that means I could muster 79 cars including one caboose. The last long US train I ran was about 60 cars long and my Big Boy ran just as it does without any consist at all. ThumpUp
I also intended to comment on your layout pictures John, but had not gotten around to it. I hope to be where you are in about three years time as I start my ultimate layout and I really like what you have done. I had not thought about a line just for my Big Boys, but that is an excellent idea.
Offline Bones
#20 Posted : 25 September 2021 10:57:40(UTC)
Bones
It should be possible to run 8 trains with them leap froging each other
It should be possible to have each loop change flip flop as each train leaves or enter's the loops and that includes the 2 reverse loops
I've been having trouble trying to decide how to automate my layout and have decided to use circuit tracks for 2 reason's
I want to have bidirectional running and I don't like cutting the tracks however I will use contact tracks in the only single line I have to make sure any train inside it is detected
This page was generated in 1.277 seconds.
