Offline Maurice
#1 Posted : 20 August 2021 11:03:50(UTC)
Maurice
Hi all
Is you use a “6021 Connect” to link a 6021 to a CS do you remove the black and white transformer that connects the 6021 to the track and replace with a CS booster and track box? So basic question is - how do you power track and older controllers?
I don’t have a CS yet just trying to workout how to integrate with existing layout and keeping older 6021 and 80f controllers as well as a Central Station.
Thank you.
#2 Posted : 20 August 2021 11:23:25(UTC)
Suggest you read the 60128 manual first, if you haven't already.
https://static.maerklin....5d097e15841604050593.pdf
Also, articles like this one can be of use
https://railway.zone/pos...the-marklin-connect-6021
Offline bph
#3 Posted : 20 August 2021 11:37:27(UTC)
Originally Posted by: Maurice Go to Quoted Post
Hi all
Thank you.
1. use your old black and white transformer to power the 6021 and 80f controllers etc.
2. remove any connection between the 6021 etc and the tracks.
3. Use a Switched Mode Power Pack to power the CS3 and the tracks.
No track box is necessary.
If you plan to use a booster, eg the 60175, you can power that with a Switched Mode Power Pack or your old black and white transformer. (A Switched Mode Power Pack is recommended.)
You can also power old accessories etc with the old transformers.
(i have a cs3 and a 6021 Connec, I also have tested using the old transformer to power a 60175, but the track voltage is a bit high when I use that combination.)
Offline Maurice
#4 Posted : 21 August 2021 09:02:54(UTC)
Maurice
Thanks for all the good advice, very helpful.
thanks 1 user liked this useful post by Maurice
This page was generated in 0.265 seconds.
