Offline ocram63_uk
#1 Posted : 30 July 2021 15:14:12(UTC)
ocram63_uk
hello there, would I need a new motor kit for a DCC conversion ?
would I have to change the motor to keep it Motorola?
These are the questions 🙂
Thank you - Marco
Offline ocram63_uk
#2 Posted : 02 August 2021 11:53:33(UTC)
ocram63_uk
done a bit of reading here and there.
in December 2017 Jacques says that the motor is an LFCM
In 2008 Webmaster says that for this type of motor you need a 60904 kit, which I believe does not exist anymore.
Converting the motor of a 3089 is NOT like working on a 3048
online shop has available 60760 with decoder
online shop has available 60941, 60943, 60944
Jacques again mentions a 60944 kit to convert the 3089 and this should do the trick. Correct ?
If I do not want to convert the motor to DC I can add only the decoder 60906 ? Apart that there aren't any other AC/DC decoders available from Markln :-)
I've used Uhlenbrocks in the past but they are a bit 'useless'
Thank you
Marco
Offline ocram63_uk
#3 Posted : 06 August 2021 15:52:53(UTC)
ocram63_uk
I wrote to Marklin asking which kits I need and they told me to use the 60906 decoder as there are no retrofitting kits for this loco.
This is what I will do then.
Thank you
Offline ocram63_uk
#4 Posted : 11 August 2021 09:46:05(UTC)
ocram63_uk
UPDATE !
Looking for 3089 on ebay I have seen a lot of locos in a moltitude of bodywork conditions.
I have found some more modern ones, for instance the 33911 model
This should be a more recent production of this loco, more in scale, probably the bodywork has been retooled, the engine has been upgraded, it has a decoder and it has sound, although I don't necessarily go looking for this feature.
Buying a 3089, at whatever cost, I then have to add the cost to digitise it and I have come to the conclusion that buying an already used converted loco, although 30/40 GBP more expensive, is actually better.
Anyone has the 33911 ? Are there other versions of the 03.10 in the same 140-150 GBP / 140-170 Euros range ?
Thank you
Marco
This page was generated in 0.235 seconds.
