Offline Shermund
#1 Posted : 15 July 2021 17:59:37(UTC)
Shermund
Malaysia
Can ms2 use on 2 rail system?
I am on HO gauge at the moment. But I want to build a second set in N gauge.
Been looking around but I can't seem to figure out if marklin ms2 can control these non marklin loco.
For example, using bachmann/minitrix tracks, broadway/model house/bachmann loco, using MS2 as the control.
Is that doable?
Thanks in advance.
Offline Unholz
#2 Posted : 15 July 2021 18:28:55(UTC)
Unholz
I have been running an HO two-rail Roco-Line track oval with an MS2 for a long time (even with non Märklin locos), so this certainly works. However, I have no idea whether such a setup is also possible with N gauge.
#3 Posted : 15 July 2021 19:28:25(UTC)
Is that doable?
Thanks in advance.
Yes but i recommended maximum 14-16 volt power out to the track.
MS2 with a digital box do have power feeder at 19 VDC which seems too much for the small trains.
You can set MS2 with the DCC protocol and use all digital locomotives who have DCC protocol.
2 rail system can been use with the CS3 too if you have power feeder Märklin 60041 that can adjust two different power source.
So that means you can drive H0 and N scale with 60041 because even smaller power feed can be use for the H0 scale too.
Offline Shermund
#4 Posted : 15 July 2021 19:41:58(UTC)
Shermund
Malaysia
Thank you both for your replies.
Max 16v, how do I control that? Or more like I should not go full speed ?
Thanks again.
#5 Posted : 15 July 2021 19:44:21(UTC)
electricity runs the same no matter the colour of the wires or how the wires (track rails) are arranged. In fact tracks are not needed at all. You can connect a controller directly to the pickups of a loco on the workbench and it will work the same.
#6 Posted : 15 July 2021 19:51:35(UTC)
Don't worry too much: The power supply for the MS2 is 18 V DC, not 19 V DC.
Power goes through a bridge rectifier where the voltage will drop a bit, at the track output it goes through two transistors where the voltage will drop a bit.
Track voltage will be around 16 V.
If you are still worried, obtain a universal power supply with 2 A or more and set it to 16 V or 14 V or so.
#7 Posted : 15 July 2021 21:33:24(UTC)
But they won't go anywhere which is the whole point of model railroading!
I do take Dale's point though - the MS2 will control anything that can run on one or more of the DCC, Marklin Motorola or Marklin mFX protocols. Electricity is electricity, it will run across whatever conductor you present it with.
#8 Posted : 16 July 2021 06:58:36(UTC)
I did tested Märklins power feeder 66360 and they showed 18,5 VDC output.
#9 Posted : 16 July 2021 07:01:44(UTC)
Yes but not without digital interference.
Märklin recommended minimal use of protocol on the track.
That is way i use only one protocol when i use my digital layout.
It works fine!
Offline rrf
#10 Posted : 16 July 2021 13:31:33(UTC)
rrf
I recently purchased the Mini Trix 11100 Digital Starter set as the foundation for Beautiful Wife’s N scale coffee table layout. It came with an MS2 with a lovely green knob. The only difference between it and my Märklin MS2 is the power supply. Though as someone already noted, since they use the same track box the output voltages should be the same. The Märklin MS2 simply has the potential to provide more current.
My wife chose a DCC New York Central steamer for first her first lok. It runs quite nicely with the MS2. She then went and purchased an analog Trix Adler on eBay, which I now have to figure out how to fit a decoder in Sad
Rob
Mackenrode Wende Bahn
#11 Posted : 16 July 2021 13:52:01(UTC)
The current is limited by the trackbox - which is the same.
Higher voltage results in higher wattage while current is the same.
The trackbox does not limit the voltage, so track voltage is proportional to input voltage.
Offline rrf
#12 Posted : 16 July 2021 14:25:24(UTC)
rrf
Hello HO,
The track box limiting current rather than voltage seems odd to me. I would have expected the maximum current to be limited by the power supply.
I am away from home for the weekend. When I return home Tuesday, I’ll hook up a multi-meter to each MS 2, as well as read the rating information off of each power supply. I will then report back what I find.
Rob
#13 Posted : 16 July 2021 14:35:42(UTC)
The rating of the track box is 1.9 A.
The rating of the Märklin power supply is 2 A at 18 V.
The rating of the Trix power supply is 2 A at 15 V.
If the power supply is rated for 2 A or more the current is limited by the track box.
The voltage is not limited by the track box. The CU 6021 can reduce the track voltage, but it has a big heat sink to handle the heat. The MS2 track box does not have a heat sink.
Offline rrf
#14 Posted : 16 July 2021 17:15:30(UTC)
rrf
Thank you, HO.
That’s very interesting. Does the MS2 module itself actually accept a range of voltages (15v to 18v)? One of the functions of the track box I always assumed was to provide 5 volts DC for the MS2’s electronics.
Rob
Offline Shermund
#15 Posted : 16 July 2021 19:59:13(UTC)
Shermund
Malaysia
Ah, seemed like it is a better idea for me to grab a minitrix starter set, buying a trix ms2/3 itself is a bit more expensive than a starter set ain't it?
Offline rrf
#16 Posted : 17 July 2021 13:46:20(UTC)
rrf
It was AJCKids who pointed out to me that the Mini Trix N Scale Digital starter (MS2, power supply, track box, and track oval) was less expensive than purchasing the MS2, track box, and N scale power supply separately. As I learned yesterday thanks to forum member HO, matching the correct power supply voltage with your choice of scale is quite important.
For Märklin HO the analogous set is the 29000 digital starter with a 3 rail C Track oval. For Trix HO it’s the 21000 set with a 2 rail C Track oval. Interestingly enough, the two HO sets are priced the same at AJCKids, while the N Scale 11100 set costs $32 more. For all three it seems a better deal to purchase the set rather than the MS2, track box and power supply separately.
Rob
#17 Posted : 19 July 2021 10:21:17(UTC)
AIUI the track box provides the full DC voltage to the MS2, not 5 V.
This page was generated in 0.641 seconds.
