Offline Mr. Ron
#1 Posted : 12 July 2021 21:49:21(UTC)
Mr. Ron
The following sketch is for my catenary system. Everything is brass except for the rail which is code 70 rail. The catenary wire is made of 1/16" brass rod with a 1/16"ID brass tube on each end and a rail joiner on each end of the code 70 rail. Following the dimensions on the sketch will give you a 2-3/4" distance between the pantograph and the catenary wire. Dimensions may vary as long as you maintain the 2-3/4". All the pieces are soldered together using a resistance soldering transformer (not a regular soldering iron) That is so soldering a connection won't "un solder" previous connections.
thanks 7 users liked this useful post by Mr. Ron
Offline mvd71
#2 Posted : 13 July 2021 09:54:21(UTC)
Why??
Offline Mr. Ron
#3 Posted : 13 July 2021 18:01:04(UTC)
Mr. Ron
Why! Because I can. It costs money to try to find all the necessary parts and then no guarantee they will work.
thanks 1 user liked this useful post by Mr. Ron
Offline scraigen
#4 Posted : 13 July 2021 18:12:01(UTC)
scraigen
One might ask why about the hobby in general? For me making stuff is a big part of it as I presume is the case here too.
Must build something
thanks 1 user liked this useful post by scraigen
Offline Darren W
#5 Posted : 13 July 2021 20:34:57(UTC)
Darren W
I have thought about doing something similar with 3D printing. I have a resin printer so I could print several masts at the same time. Please post pictures I would really like to see how your catenary wire turns out.
Offline mvd71
#6 Posted : 13 July 2021 21:51:33(UTC)
Ok, fair enough. I was thinking by the time you bought all the materials and did the work…… but each to their own ThumpUp
Offline Mr. Ron
#7 Posted : 14 July 2021 04:50:13(UTC)
Mr. Ron
I used code 70 rail, 1/16", 3/32" brass rod and code 70 rail joiners and 1/13" ID brass tubing. The material cost is a lot less than buying ready made poles and catenary wires. All told, I think I came in at around $35. I should be able to get 20 poles and enough cat wire to cover about 24 feet. BTW, I used the code 70 rail upside down so the pantograph makes contact with the rail head. With the rail joiner, a nice smooth contact is made. I'm not sure if I will solder the joiners. I will see how continuity is; same with the tubing. I still have to design and make some structure for spanning 2,3 and 4 tracks.
Offline Mr. Ron
#8 Posted : 14 July 2021 05:01:47(UTC)
Mr. Ron
I have made one 14" length of catenary and it turned out so-so. I need to make a jig to hold everything in alignment while I solder it. Jigs are absolutely essential for repetitive work. Time spent making a good jig is time well spent.
I'm having health problems (my wife's), so I can't devote as much time as I would like. Traditionally, I work slow as I am not in any hurry. I find the thinking, planning and actual making is satisfying, but I will try to post some pictures after I figure out how to post them. I went from an XP computer to a windows 10 and am still trying to figure it out.
This page was generated in 0.527 seconds.
