Offline mvd71
#1 Posted : 27 June 2021 00:34:50(UTC)
Dumb question for the day. How many connect 6021 (60128) units can be connected to a cs3?
#2 Posted : 27 June 2021 00:41:27(UTC)
Why, how many 6021s do you have?
I would have thought that the connect6021 would look something similar to an ms1 to a central station.
Offline mvd71
#3 Posted : 27 June 2021 01:52:44(UTC)
Why? Because I can!
Actually it’s because I would like to implement a control system with a controller at each station, and the 6021 is the best option in my view due to its speed and ease of operation. The CS3 is planned to be a hub to process signals from 6021’s and associated components.
Anyway, if someone has tried plugging in multiple units I would like to hear how they got on and if there were any issues.
Cheers…..
#4 Posted : 27 June 2021 02:06:40(UTC)
You need the connect 21 unit and adapter cable.
Offline mvd71
#5 Posted : 27 June 2021 03:56:33(UTC)
Actually I need several of the connect 6021 units (60128) and a terminal (which I have already) and of course several 6021 units.
But I’d like to know if someone has tried even two units plugged into the cs3 before I spend too much
#6 Posted : 27 June 2021 06:59:54(UTC)
May I request that you not be so glib
You do not need an adapter cable to connect the 7 pin Connect6021(60128) cable to either a CS (2/3) or Terminal (60125/60145)
The CS3 (60226) natively supports 2 x (7 pin) devices be they Connect6021(60128), Boosters or LinkS88(60883)
For more than 2 devices you would add a terminal (60125/60145) - not an adapter cable
The 60124 (Originally part number #610479) - 10 pin to 7 pin adapter cable - is only needed for Mobile Stations (When adding a 3rd unit at the back of the CS or via the terminal)
Edited by user 27 June 2021 23:50:22(UTC)  | Reason: Not specified
#7 Posted : 27 June 2021 07:01:28(UTC)
But I’d like to know if someone has tried even two units plugged into the cs3 ..
I can vouch for 2, I can test 3 next weekend if you need.
(In theory the architecture supports a UID address space of 4 billion devices although the 60128s appear to be using the x36 x30 prefix with the next 2 bytes based on the items serial number, so you may be down to 65 thousand)
Still happy to send you a unit (as discussed last year)
Edited by user 27 June 2021 23:51:21(UTC)  | Reason: Not specified
Offline mvd71
#8 Posted : 27 June 2021 08:15:22(UTC)
Thanks Peter, I think a paltry 65 thousand is probably still one or two more than I could use! 😊
#9 Posted : 28 June 2021 13:30:53(UTC)
Huh How was I glib? With so many connectng items and terms for the CS3, one can forget certain aspects and confuse things. Yes, the 6021 connect ubit has it's own cable.
#10 Posted : 29 June 2021 03:27:22(UTC)
Huh How was I glib?
You stated ...
which is blatantly false
By making unfounded comments you are ADDING to confusion rather than being helpful
#11 Posted : 29 June 2021 13:31:19(UTC)
Yet my explanataory rebuttle holds no merrit and you two ally from accross the ditch down under. As if to say no other's post replies which aren't helpful.
#12 Posted : 29 June 2021 14:00:32(UTC)
Confused Confused Confused
#13 Posted : 29 June 2021 14:16:31(UTC)
Not surprised!
#14 Posted : 29 June 2021 15:04:45(UTC)
I don't understand this. I am not a native English speaker.
But maybe I am not supposed to understand this. Wink
#15 Posted : 29 June 2021 15:51:59(UTC)
No, I think you have got the idea, Tom Wink
#16 Posted : 29 June 2021 16:11:28(UTC)
Could you please explain a little further?
#17 Posted : 29 June 2021 16:30:30(UTC)
I also ahve never before heard the word glib. I looked it up.
After being chastized by Clapcott as posting an unhelpful reply, rather than accepting that I explained I mistook the lack of a supplied cable with the 6021 connect, P.J. also from N.Z. aggreed with him.
I stick up for myself and can be just as much of a b_ _ _ h as the anyone.
#18 Posted : 29 June 2021 17:43:04(UTC)
I think you missed the part where it tells you that this forum is about being helpful and friendly Laugh
#19 Posted : 29 June 2021 18:23:00(UTC)
No, and that is a two way street! From now on, I'll try ignoring ignorance or brashness.
#20 Posted : 29 June 2021 21:12:35(UTC)
Actually not................. BigGrin
Help is given from those who knows, to those who doesn't know Cool
Going in the opposite direction on your two way street doesn't really make any sense, and surely doesn't help anybody BigGrin
A similar situation goes for being friendly; if you don't accept the friendly-ness given to you; but instead return it, then you got nothing.
I saw that a few days ago when I commented your "joke" in the NMR-section Cool
#21 Posted : 29 June 2021 22:46:39(UTC)
Excuse' moi', Touche' Not everyone likes every joke. Not everyone likes everyone else either, and they don't have to. I am not rude unless it is first intitated to me. I did not reply in a GLIB manor as previously acused of. The era of my day job has quite some time been termed.
In my/our circles, those who know know not to mess with eh-em, our kind as some say. Happy Pride!!!!!!
#22 Posted : 30 June 2021 00:58:15(UTC)
OK Guys, this has gone far enough so that we are not even on the original topic anymore. Time to lock the thread.
Sorry if Peter came across as direct to the point, but Peter is a direct to the point kind of person. He wasn't trying to offend anyone, rather he was correcting bad information which as we all know can bring about confusion. No one was trying to personally attack you marklinist5999, and I suggest you don't need to be so thin skinned about it. Not sure what your final statement is intended to mean, but it could almost be read as a kind of threat which if it is will not be tolerated on this forum.
Edited by user 30 June 2021 04:34:28(UTC)  | Reason: Not specified
This page was generated in 0.690 seconds.
