Offline ocram63_uk
#1 Posted : 27 June 2021 15:07:35(UTC)
ocram63_uk
I have to replace a bogey of The tender of the 3048 loco I bought with the 3148 set. Bogey arrived. I can't unscrew the screw that is holding it in place. The head of the screw is getting damaged by the flat screwdriver that skids off it. I have sprayed the screw with WD-40 screw unblocker bit it isn't getting me anywhere. Has anyone got a working methodology ? For one I'll have to thin the blade of a bigger screwdriver and see if this works as well. The one I've been using doesn't cover the whole of the screw head but only the center part.
#2 Posted : 27 June 2021 19:58:54(UTC)
I'd leave it 24 hours for the WD-40 to soak down the thread. The other trick I have used is to alternatively tighten and loosen the screw to break whatever corrosion has bound it in the thread.
Offline Mman
#3 Posted : 27 June 2021 23:57:07(UTC)
Mman
The screw may have been installed with a thread locking adhesive.
Essential to get a screwdriver to fit exactly before further damage. After letting WD soak in, if that doesn’t work try heating the screw with a soldering iron pressed to it.
ChrisG
Offline ocram63_uk
#4 Posted : 28 June 2021 00:22:52(UTC)
ocram63_uk
Thank you Alan, Chris.
The soldering iron do I place it on the ending bit of the scrw or on the head? If I heat the screw doesn't it expand ?
I have found a seller that has the screws on the 'bay' so I might get then just to be sure everything is back in pristine condition after I finish.
Offline Mman
#5 Posted : 28 June 2021 08:04:48(UTC)
Mman
Put the iron wherever you can get at the screw, the screw expanding slightly may break any seal, when it cools try undoing it again. Usually I use a blow torch on seized (big non Märklin) bolts but that would not be practical in this case (or wise!).
Good luck.
ChrisG
Offline ocram63_uk
#6 Posted : 29 June 2021 18:30:22(UTC)
ocram63_uk
SOLVED
The trick suggested by Chris did it, massive thank you. No locking adhesive.
First of all I 'slimmed' the tip of a bigger screwdriver, the ones I had managed to fit only half the lenght of the screw head and were too big.
I applied heat once and tried unscrewing, nothing happened.
Heated it again but this time, with the screwdriver in the screw head, I gave a couple of bangs with a hammer on the handle of the screwdriver and then applied as much torque as my wrists allow me to these days, the screw budged.
Bogey replaced :-)
The question now is, do I order the original set of new screws and replace the 'damaged' one or leave it as is ?
Cheers - Ciao
Marco
Offline ocram63_uk
#7 Posted : 20 July 2021 09:43:05(UTC)
ocram63_uk
Thank you all for your help and support !!!
#8 Posted : 20 July 2021 10:12:02(UTC)
I've found it too, these screws are very solid screwed down, a proper screwdriver is needed to undo it otherwise we follow your senario
This page was generated in 0.331 seconds.
